Author Topic: GM Dana 60 spring plate bolt to housing torque spec  (Read 21926 times)
Offline berserk
« on: July 08, 2022, 01:33:44 am »
I am in the process of installing 1 ton axles in my K10 Chevy. A few days ago I put the u-bolts and spring plates on my Dana 60 and torqued them down to 150 ft lb per Chilton's manual. It occurred to me yesterday that on the passenger side two of the bolts thread into the housing and may have a different torque spec than the U bolts. At the moment the bolts are torqued to 150 ft lb just like the u-bolts. I have looked through my Haynes manual, Chilton's manual, Dana 60 and Military CUCV Manual. All my manuals list U bolt torque but say NOTHING about the spring plate to diff housing bolt torque.
I'm inclined to leave the bolts the same torque as the u-bolts. But I do have some concern about how tight they are. Any reference material or experience would be helpful.
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
Re: GM Dana 60 spring plate bolt to housing torque spec
« Reply #1 on: July 08, 2022, 06:11:35 am »
Post a pic of which bolts you are referring to
Offline berserk
« Reply #2 on: July 08, 2022, 09:17:30 am »
The new grade 8 bolts on the left are what Im talking about. On the Dana 60 these bolt the spring plate directly to the housing instead of a 2nd U bolt. Cant find the torque specs anywhere for these specifically.
« Reply #3 on: July 09, 2022, 05:57:24 pm »
150
Offline berserk
« Reply #4 on: July 11, 2022, 01:27:56 am »
Thank you so much! After I couldn't find it in several of my manuals I knew this forum would have the answer!
