Author Topic: Stalling  (Read 5846 times)
Offline Nikodemus
  • Constantly broken
Stalling
« on: February 10, 2007, 10:12:00 pm »
This is a long story so bare with me. I purchased two trucks last year a 1978 K-20 Silverado dieing of rust but with a strong drive train and a 1977 C-10 Scottsdale with a nice body and a dead engine. The K-20 ran fine nothing wrong with it at all never had any trouble. I swapped the engine from the K-20 into the C-10 and replaced the stock carb with an edelbrock from the dead engine that was originally in the C-10. The previous owner of the C-10 said it was a new carb...and it did look new.
After the engine swap the C-10 never ran right. I took it on a long hellish camping trip where it performed beautifully on the freeway but as soon as I pulled off the freeway and stopped at a stop light or stop sign the trucks idle would become very rough and it would die. Afterwards it was very very hard to get it started again (but it would always start up again thank God).
This winter I was driving it around a little bit and didn't encounter the problem again until the temperature got a little higher (above freezing). Now it's doing it again. I can start the truck in the morning and its fine but as soon as I take it for a short 10-15 minute trip and its warmed up it will start to idle really when I come to a stop.
I couldn't find anything wrong so I took it to a mechanic and he said there was a vacuum leak. He fixed it for free and I was on my way. But yesterday the problem was back again. I was idling at a stop light when I could feel the engine starting to die on me. I had to hold down the break and give it gas to keep it running.
When I got to work I put it into park and turned it off and then started it back up again after about 10 seconds and the idle was really bad it was barely running I let it idle like that for about 10 seconds and then it stalled.
I really need this problem resolved because this is my daily driver and it's barely getting me to where I need to go. Not to mention my wife refuses to drive it because she's scared to get stranded somewhere. So any help is greatly appreciated.
Re: Stalling
« Reply #1 on: February 10, 2007, 09:49:00 pm »
rebuild your carburetor, make sure your floats float and are ok. Replace the needles and seats, pull out the sock screens and get rid of them. Make sure you have a good inline fuel filter before the carb. Make sure the jsts are clear and blow everything out good with compressed air. Float level and float drop are very important. Make sure the carb base is not warped. you should tighten it in an x pattern and do not over tighten it. Use a good base gasket. I've had the same problems with those carbs.
Offline Nikodemus
  • Constantly broken
« Reply #2 on: February 11, 2007, 10:42:00 am »
What type of carb would you recommend? If I was simply to replace the edlebrock one?
Re: ...
« Reply #3 on: February 12, 2007, 06:21:00 pm »
A rebuild kit is like $25 bucks and they don't get easier then those AFB Edelbrocks. The best bolt on carb is a reman Qjet. Easiest to play with = Edelbrock
Offline xtreme80
Re: ...
« Reply #4 on: February 15, 2007, 09:08:00 pm »
Would have to agree with VZ there.  Sounds like the carb is leaking fuel into the engine.  Mine had the same problem.  I've rebuilt my carb 3 times, doing all the steps that VZ mentioned, and it still does it sometimes.  You may also want to JB weld the fuel well plugs, cuz Ive heard horror stories about those leaking.
As for a new carb, I would recommend either a replacement Q-Jet or a carter AFB
Offline Nikodemus
  • Constantly broken
« Reply #5 on: February 15, 2007, 11:41:00 pm »
Still does it!? Now that's depressing...:\
Re: ...
« Reply #6 on: February 16, 2007, 04:41:00 pm »
elaborate
Offline Nikodemus
  • Constantly broken
« Reply #7 on: February 20, 2007, 04:09:00 pm »
Looks like you were right the floats aren't floating.
