Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
A/C Thread Sizes
Topic: A/C Thread Sizes (Read 10791 times)
ehjorten
A/C Thread Sizes
August 30, 2022, 11:53:20 am »
What are the two different thread sizes on our A/C systems? I need to order fittings to make custom A/C hoses for my 1991 V3500 and I am not certain the size and thread pitch. I think they are 7/8"-14 and 3/4"-16, but I am not certain.
-Erik-
ehjorten
Re: A/C Thread Sizes
August 30, 2022, 08:50:46 pm »
So I am thinking that my 1991 V3500 has metric threads on the accumulator...M27x2.0 for the connection to the low-side suction line to the compressor, and I am guessing that the discharge line to the condenser is a M20x1.5, but I am unsure because I don't have any nuts to check that this is the case.
The LS conversion Sanden SD7H15 compresser has 3/4"-16 and 7/8"-14 connections.
Last Edit: August 30, 2022, 09:02:38 pm by ehjorten
-Erik-
September 02, 2022, 03:55:09 am »
If you are making your own, you can order beadlock fitting assortment kits really cheap on eBay. I had a hard time finding the one at the accumulator, so I cut the hose off of the oe one, and crimped a new shell to the stock fitting. Look here too
https://coldhose.com/collections/fittings
Scott91370
September 06, 2022, 11:48:39 am »
Here is what I found but cannot confirm it 100% (and it is for the 85).
Compressor to condenser top- #8 to #8 O-ring - DISCHARGE side of compressor
Condenser to evaporator bottom #12 O-ring to #6 O-ring - Contains Orifice Tube
Drier is mounted on the upper 3/4" fitting on the evaporator - no hose
Drier to Compressor #10 to #12 (3/4") o-ring - SUCTION side of compressor
A/C Thread Sizes
