Author Topic: Which vent window seals to use  (Read 7079 times)
Offline Ben_Olddermin
« on: September 01, 2022, 03:35:29 pm »
I had my vent window seals replaced 10 years ago but I don't remember if they were 1 piece. Maybe they were the two piece variety. So I wanted to ask if it's possible to screw up and use the wrong one. What would happen if you did that?
I need to order new seals and I want to make sure I get the right ones. Thank you
Offline Scott91370
Re: Which vent window seals to use
« Reply #1 on: September 06, 2022, 11:51:43 am »
« Reply #2 on: September 06, 2022, 05:46:29 pm »
Looks like 70's was 2 piece, 80's trucks were all 1 piece.
Offline Rapid Roy
  • Euless, Texas
« Reply #3 on: September 06, 2022, 06:45:02 pm »
My 74 are one piece.
Mopar by Birth
Chevy by Choice
« Reply #4 on: September 07, 2022, 09:32:47 pm »
Did yall have to go back and seal up the air leaks once you replaced yours? I got them all replaced but they are quite noisy. Checked them over as well as you can once they're back on the truck. Nothing wrong. But a lot more air noise than there used to be.
« Reply #5 on: September 08, 2022, 05:34:42 pm »
Rebuilding them can be a pain and then to have them be noisy afterward would not be fun. Is the frame bent, rivet installed correctly, seals fully seated, does it shut all the way tight against the seal? I bought a few sets of the aftermarket ones and they were nice and tight.
« Reply #6 on: September 12, 2022, 03:33:04 am »
I thought they were sealed correctly but I will go back and check them thoroughly. I will also check the rivets and make sure it's good there. They do seem to shut tight against the seal.
If I can't get them quiet there's always silicone I guess. I believe there may be a way to silicone them without it being visible. If successful it would kill the air leak because no more holes. Air leak must be sealed cause it may also be a water leak.
« Reply #7 on: September 12, 2022, 06:22:40 pm »
Sealing them shut with silicone would defeat the purpose of having them. Go for a drive with a passenger, shoot them with foaming glass cleaner and pinpoint the leaks.
Offline MY1978
  • Just a girl and her truck since 1978
« Reply #8 on: September 18, 2022, 07:46:44 am »
I replaced my vent window seals and what a pain to find the right fit.  I ordered from several different vendors and could not get a good fit.  I needed 2 different types of seals.  My driver's side was the press in on the center bar.  My passenger had the clips that you bend over.  I eventually bit the bullet and just shipped my vent windows out to Precision and had them install the seals.  They came back still a little noisy.
« Last Edit: September 18, 2022, 07:49:52 am by MY1978 »
