Author Topic: 87 V10 TBI - No check engine light & inconsistent idle  (Read 31770 times)
Offline buzzman351
« on: September 26, 2022, 05:40:51 am »
I have been replacing components lately and have seen the posts on how to check for codes but i have no check engine light. i actually reached up behind the cluster and it feels that where the CEL should be is just a plug. any ideas?
Re: 87 V10 TBI - No check engine light & inconsistent idle
« Reply #1 on: September 26, 2022, 08:41:07 am »
The bulb socket may not have good electrical connections with the PCB, the bulb could be burned out or simply missing.
Offline buzzman351
« Reply #2 on: September 30, 2022, 06:19:27 am »
theres a plug in its place like it didnt come with one and i was reading a diagnostic page and the instructions had (for trucks with CEL)
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: October 01, 2022, 11:32:30 am »
What is the 'plug' that's in its place?
1980 C-10 under construction
Offline buzzman351
« Reply #4 on: October 11, 2022, 05:34:54 am »
the CEL light port where the bulb should be is capped off. i havent found a wire that would hook to a bulb. ive also seen write ups saying CEL is not present on some vehicles. that being said is there a digital scan tool that i can purchase to read diagnostics. trying to stay under 200 bucks
Offline buzzman351
« Reply #5 on: October 11, 2022, 05:53:31 am »
or is there anywhere i can tap in with a test light to get the flashing codes?
« Reply #6 on: October 11, 2022, 05:48:45 pm »
There is no 87 K10 so are you sure your truck is an 87? Is it TBI?
Offline buzzman351
« Reply #7 on: October 12, 2022, 11:09:43 am »
Ok 87 V10. Yeah I’m sure
Offline buzzman351
« Reply #8 on: October 12, 2022, 12:46:45 pm »
But a scan tool recommendation would be greatly appreciated
« Reply #9 on: October 12, 2022, 02:01:26 pm »
Post a pic of the instrument panel from the driver's seat and a pic of the "plug" that fills the CEL hole.  Is there an ALDL connector mounted under the dash?
Offline buzzman351
« Reply #10 on: October 16, 2022, 06:19:29 am »
I have changed out the MAP, TPS, IAC, EGR solenoid and valve, CTS. probably missing something but this is a TBI off of a 94. i had to splice in a TPS harness. the wire colors were the same so i figured it was all good. i can set base idle to about 750 and it will run at that idle for a bit. the next day it will go back to being around 1000. i performed the idle procedure that i found in the forum. ive sprayed throttle body cleaner around all hoses and gaskets. i even set timing again. any help?
  • Old Goof
« Reply #11 on: October 16, 2022, 02:47:27 pm »
Have you looked for bad grounding wires?
Offline buzzman351
« Reply #12 on: October 16, 2022, 03:11:59 pm »
I did clean up the grounds that are by the thermostat. 2 of them. What others should I look for
  • Old Goof
« Reply #13 on: October 16, 2022, 04:46:02 pm »
I've seen them on the firewall and passenger fender.
Offline buzzman351
« Reply #14 on: October 16, 2022, 05:15:46 pm »
I’ll check those as well
