Author Topic: 87 k10 350 tbi tuning?  (Read 47622 times)
Offline buzzman351
Re: 87 k10 350 tbi tuning?
« Reply #15 on: October 11, 2022, 06:03:09 am »
i probably should add that my original TBI was toast so i bought one from a guy that was on a 94 chevrolet. i had to wire a different TPS connector but everything else hooked up as it should
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: February 14, 2023, 04:59:24 pm »
Finally replaced the O2 sensor, definitely made a difference in that the feathering action takes it to a higher RPM.
Still won't idle
Smells rich
Since I had B+ disco'd there are no codes, so will have to do the feather dance till some get thrown.
1980 C-10 under construction
« Reply #17 on: February 15, 2023, 05:40:56 pm »
Smells rich, won't idle, did you disconnect the vacuum hose at the EGR valve?
  • Old Goof
« Reply #18 on: February 15, 2023, 07:45:29 pm »
Not that I'm aware of, will check tomorrow. Thx!
« Reply #19 on: February 16, 2023, 03:52:34 pm »
I am suggesting that you do to see if it is hanging open.
  • Old Goof
« Reply #20 on: February 17, 2023, 02:40:20 pm »
Got it, thanks!
I looked yesterday, there is a electronic module between it and the source.
« Reply #21 on: February 17, 2023, 07:09:16 pm »
Just pull the hose off of the EGR valve and let it dangle in the wind. See if it affects the way it runs.
  • Old Goof
« Reply #22 on: February 22, 2023, 03:59:59 pm »
VZ
It definitely changed the way it behaves, tried to idle, I can now feather it to much higher RPMs.
Looks like it's stuck? Any thing else to add?
Thanks buddy!
« Reply #23 on: February 22, 2023, 06:09:23 pm »
You should have no vacuum at the hose to the EGR valve with the engine running. If you do, replace the EGR solenoid.
« Reply #24 on: February 23, 2023, 09:31:34 am »
In addition to vacuum bleeding past a faulty EGR solenoid, an EGR valve is susceptible to carbon accumulation that can prevent seating of its pintle allowing exhaust to bypass the valve.  To check the EGR valve for bypassing, remove it from the manifold and flip it upside-down.  The pintle and seat are inside the short steel tube protruding from the base of the valve.  Dribble some penetrant (e.g., carb cleaner or penetrating oil) into the open end of the tube without disturbing the valve diaphragm.  If the penetrant leaks past the pintle and seat into the underlying chamber, the valve is bypassing and should be replaced.  A valve in good condition will not bypass at all.  Be sure to install a new gasket.
  • Old Goof
« Reply #25 on: February 23, 2023, 01:03:21 pm »
Thanks guy, I'm on it!!!
  • Old Goof
« Reply #26 on: March 13, 2023, 03:50:54 pm »
Finally got the EGR off, with the help of a box end 1/2 inch wrench with a curious 115 degree bend. Custom made with the help of my torch...
Doing the leak down test now.
I can blow air through the module from either of the tubes. Just curious if when power is applied a valve closes.
Napa lists the module as an "Eichlin air filter".  ???
« Last Edit: March 13, 2023, 10:59:53 pm by JohnnyPopper »
  • Old Goof
« Reply #27 on: March 13, 2023, 11:00:47 pm »
Leak down failed.
Ordered parts, will keep you posted. THANKS!!!!
« Reply #28 on: March 14, 2023, 06:21:30 pm »
There's a small foam filter on the solenoid. I'm not sure exactly what you are working on since this thread says 87 k10 (which is a V10) and you mentioned an R30?
  • Old Goof
« Reply #29 on: March 15, 2023, 09:03:09 pm »
Yeah sorry, I hijacked a 87 K10 thread with my own silly problems...
It's a '88 1 ton w/454/400 TBI.
Their is a filter on the solenoid.
Q: when the solenoid is energized is there a valve that forced closed?
In the absence of 12v, I am able to blow through either port.
Just wondering if I need a new solenoid.
Thanks!
