Author Topic: Possible bent frame on a 74 c15  (Read 12607 times)
Offline Swampyankee74
  • Keep em alive
« on: October 15, 2022, 03:16:07 pm »
I am stripping my truck down, I get the nose off and the frame looks slightly tweaked towards the passenger side on both front rails. Everything appears to be good from the a-arms back. I know the truck was involved in 2 small front end collisions. I drove the truck for a couple months. Seemed to drive fine.
I wanted to see how out of square it was so I took a dot box laser and marked both front cab mount bolts on the floor and then marked both radiator core support mounts on the floor and cross measured them. One cross measurement was an inch bigger then the other supporting my theory on the direction I beleave the frame to be bent. It's 1 inch with tells me it should be brought back a half inch. Would it be overboard to have it straightened or is it fine how it is? Am I going to have a major issue getting the front body back on correctly?I'm not building a show truck. Looking for some ideas or guidance.  I'll try to post some pics
  • Keep em alive
Re: Possible bent frame on a 74 c15
« Reply #1 on: October 15, 2022, 03:19:45 pm »
Pic
  • Keep em alive
« Reply #2 on: October 15, 2022, 03:20:48 pm »
Pic
« Reply #3 on: October 15, 2022, 06:33:32 pm »
Build or buy a tram gauge to measure it. You need a little movement to get your body lines right. These frames settle and twist so make sure it's on its wheels, tire pressures are good, spring height is right,  everything is perfect before you do. You'll need shims regardless
« Last Edit: October 15, 2022, 06:39:10 pm by VileZambonie »
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: October 15, 2022, 06:34:53 pm »
Yeah it looks like it got smacked but not hard.
I wouldn't sweat it unless you feel compelled.
You can heat the horns where they converge to the main part of the frame and tweak them. Is it both of them? Passenger is visible, other not so much.
Reminds me: a guy came in that had drove his new Corvette into a bank. We had to get that girl red hot with the biggest rosebud we could find, hydraulics, chains and sweat.
She left square, slight dent that no one would care about.
1980 C-10 under construction
Offline Mike81K10
« Reply #5 on: October 15, 2022, 09:29:11 pm »
Could find a straight frame from a salvage yard!
  • Keep em alive
« Reply #6 on: October 16, 2022, 08:11:49 am »
I got to look into the tram guage. I believe both are bent I had a bumper on the front so that must have kept the frame spread.
  • Keep em alive
« Reply #7 on: December 17, 2022, 08:52:35 pm »
The frame is straight! My cousin and I have about 8 hours into setup and tweaking. But she is nice and true.
  • Keep em alive
« Reply #8 on: December 17, 2022, 09:05:32 pm »
Straight and true
  • Old Goof
« Reply #9 on: December 17, 2022, 10:08:58 pm »
So are these after pics?
  • Keep em alive
« Reply #10 on: December 18, 2022, 04:36:05 am »
Yes they are after pics
« Reply #11 on: December 18, 2022, 08:08:27 am »
Congratulations! What is your measurement at the blue line?
  • Keep em alive
« Reply #12 on: December 18, 2022, 08:15:41 am »
I beleave it was 28. I can check when I get home
  • Keep em alive
« Reply #13 on: December 18, 2022, 08:18:10 am »
28 was outside edges of frame rail.
  • Keep em alive
« Reply #14 on: December 18, 2022, 08:33:28 am »
25-7/8 between the 2 dog bones on the skinny part
