Author Topic: Engine diesels after carb swap  (Read 6114 times)
Offline 87K104X4
« on: February 24, 2007, 06:09:00 pm »
I replaced the Q-jet on my truck last weekend with an edelbrock 600 and now when I shut the truck off it diesels (keeps wanting to run). It never did this before the swap and I even replaced the plugs and wires but no help. Anyone know what to look for? I have tried to adjust the timing and this didn't help. Any help would be great. Thanks
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Engine diesels after carb swap
« Reply #1 on: February 24, 2007, 07:12:00 pm »
A lot of times the cause for dieseling is too low of octane used.   A lot of performance engines require more octane.  If you put 92 octane in it, i bet your dieseling goes away.
However, you state it didn't occur with the old carb.  My guess is air is getting through somewhere.  A vacuum leak, carb gasket leak--something like that is the culprit.
For a quick rememdy, turn ignition off when you are still in gear.  It will stop immediately. Then with key half way off (auto trans) put it in park then take key out.
Grab some WD40 and spray around vacuum lines and gaskets with engine idling.  Just be careful with the stuff, it is flammable.  If rpms go up, you found a leak.
Also, double check your timing and set idle rpms to where they should be--around 750.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 2/24/07 7:14 pm
Offline 75 C20
« Reply #2 on: February 24, 2007, 08:48:00 pm »
my 75 use to diesel a bit after i put my edelbrock carb on it- i set my idle to a lower rpm and that stoped it- it now idles at about 600-650 and she hasnt dieseled since
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline 87K104X4
« Reply #3 on: February 25, 2007, 04:57:00 pm »
I tried the wd-40 trick but cannot find a vacuum leak anywhere. One strange thing about the timing was when I hooked the light to it I could not get the mark on the balancer to show up on the tab unless I dialed around 30-35 degrees on my light. The vacuum advance was unhooked so I don't know what would cause that. Got any ideas?
Offline roundedline
« Reply #4 on: March 01, 2007, 04:41:00 pm »
Put the number 1 piston on TDC and check your mark.  If it is off you outer ring has slipped.  You can remark it with some white out and recheck the timing.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 87K104X4
thanks
« Reply #5 on: March 01, 2007, 05:22:00 pm »
Thanks for the info. As soon as the weather comes around I will try that.
Re: thanks
« Reply #6 on: March 01, 2007, 06:49:00 pm »
What is your engine idling at? ______RPM
Offline 87K104X4
no tach
« Reply #7 on: March 03, 2007, 08:52:00 am »
I don't have a tach so I don't know for sure. I am just setting it by ear.
