Author Topic: Cab floor brace support  (Read 24994 times)
Offline philo_beddoe
  • 77 C-10
« on: December 04, 2022, 07:54:57 am »
What’s involved in replacing this cab floor brace support? It looks like more than the two bolts. Some spot welding? My passenger side is great, the drivers side is rotted around where the support bolt goes through.
Forgot the pic, but most know what I’m referring to.
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-319-320&Category_Code=C1
« Last Edit: December 04, 2022, 05:32:17 pm by VileZambonie »
Re: Cab floor brace support
« Reply #1 on: December 04, 2022, 08:52:13 am »
Take out inner fender, loosen body mounts, jack up cab, cut, drill, grind, repair, patch, & weld all associated parts, lower cab, measure shim, adjust. Use rust protection on all areas. Should only take like 5-10 minutes.  8)
  • 77 C-10
« Reply #2 on: December 04, 2022, 03:09:06 pm »
Lol, sounds like an all-day-er!
Now you know why I have the “DOH!” Homer avitar.
« Last Edit: December 04, 2022, 03:12:10 pm by philo_beddoe »
  • 77 C-10
« Reply #3 on: April 28, 2024, 10:31:56 pm »
Well, two years later,,,finally got around to replacing that cab floor brace,,, sort of. Turns out the rotted section never reached the cab mount. So we cut out the bad section and welded in the exact shape piece needed, trimmed and painted. Done!
« Reply #4 on: May 01, 2024, 05:33:41 pm »
That's the beauty of repair panels is they give you pieces.
  • 77 C-10
« Reply #5 on: May 21, 2024, 06:45:42 pm »
Oh, ignore that ugly exhaust, since this post the entire exhaust system has been replaced,,,,to a proper factory correct system, still single exhaust, but came out wonderfully.
