Author Topic: GM2700 AM FM Radio Issue  (Read 6713 times)
Offline Rapid Roy
  • Euless, Texas
« on: December 04, 2022, 09:58:53 pm »
Recently installed used radio. All works except when radio is on when key off,  radio is not on when key on. I could not use the OE power connector, so connected power wire to newer connector. When key on, have to turn radio off then on and works. This is the second radio since purchase and did not have this with the previous install. Kind of confusing but am still able to use radio.
Any ideas?
Mopar by Birth
Chevy by Choice
Re: GM2700 AM FM Radio Issue
« Reply #1 on: December 05, 2022, 04:10:00 pm »
I'm confused about what you are saying/asking. Are you saying the radio does not work when the ignition switch is in the run or accessory position but works with the ignition switch off?
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: December 05, 2022, 04:51:24 pm »
Ok. I'll try again. When engine on, radio is on, no issue. Turn key off, (the radio was playing) then restart, radio does not automatically play. If I turn radio power off then on radio plays fine. This is a strange issue for me cause I have never had one do this.
Mopar by Birth
Chevy by Choice
Offline Chevygold
« Reply #3 on: December 07, 2022, 07:12:19 am »
Is the permanent live hooked up?
Graham
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: December 07, 2022, 07:45:31 pm »
I've come to the conclusion that there are things 'too wonderful' to understand... ;)
Are you cycling power, i.e. kill engine, then instantly restarting?
How old is the radio? Transistor or semi conductor?
1980 C-10 under construction
