Author Topic: bounce stall  (Read 3376 times)
Offline thirstycanadian
bounce stall
« on: March 06, 2007, 07:26:00 pm »
I've been having an ongoing problem with my 85 1 ton (454, original Rochester).
Sometimes when I bounce the truck hard (bad railroad tracks, etc) it sputters and stalls out.  It does not happen everytime I hit a bad bump, but it never stalls otherwise.  I obviously try to keep things from getting too bumpy, but it happens.
It acts kind of like it has flooded, because it will usually start back up after having a few minutes to breath....but a lot of the time, once it starts again it won't hold an idle, but I can keep it running if I keep the RPMS up....which makes me think it might be a vacuum leak, even though if I don't hit a bump it idles fine.
Any ideas of what to look for?  Thanks
Re: bounce stall
« Reply #1 on: March 10, 2007, 07:54:00 am »
Your float level is incorrect. Replace the needle and seat and adjust the float level and float drop. If you do a lot of offroading use a spring loaded neddle
