Author Topic: Why doesn’t this line up?  (Read 21078 times)
Offline philo_beddoe
  • 77 C-10
« on: December 30, 2022, 09:08:16 am »
Anyone with a little OCD, this would bother you. Should I put both legs on the steering column and give a good shove? Probably not..
Offline Scott91370
Re: Why doesn’t this line up?
« Reply #1 on: December 30, 2022, 09:31:22 am »
I'm guessing you mean the pointer with the letters?
There is a wire that connects the pointer to the column by way of a small clip on the right hand side.  It has probably moved.  I think if you remove the lower trim portion of the column you can see it and adjust it by just moving it ever so slightly.
https://www.youtube.com/watch?v=zsoN91hUqxY
Online bd
« Reply #2 on: December 30, 2022, 09:54:35 am »
You may achieve limited lateral adjustment by loosening the two, column mounting nuts below the dash and/or the column mount at the firewall.
  • 77 C-10
« Reply #3 on: December 31, 2022, 11:35:36 am »
Ok bd, will try that. Thanks!
  • 77 C-10
« Reply #4 on: December 31, 2022, 11:41:30 am »
No, where the column meets the bezel.
« Reply #5 on: December 31, 2022, 01:46:07 pm »
Is the bezel the correct one and properly seated?
  • 77 C-10
« Reply #6 on: January 13, 2023, 09:16:37 am »
I believe it’s the original, but good point, will check that first, thanks.
