Author Topic: Ready to be blasted  (Read 95536 times)
Offline macr0w
Re: Ready to be blasted
« Reply #150 on: June 11, 2023, 06:25:11 am »
Dude!!!
You are killing it.
That thing is going to be so nice when you finish it up.  8)
« Reply #151 on: June 11, 2023, 06:25:27 am »
Coming along nicely
Offline Swampyankee74
  • Keep em alive
« Reply #152 on: June 11, 2023, 07:56:54 am »
Thank you. I've never been this deep into a vehicle.  There's a whole lot of learning going on. A lot of one step forward then 2 back haha
Sent from my SM-S515DL using Tapatalk
Offline Shifty
  • I bleed Bowtie red...
« Reply #153 on: June 13, 2023, 09:25:21 am »
Looking great man!
98 C2500 ext cab longbed
  • Keep em alive
« Reply #154 on: June 18, 2023, 07:36:53 pm »
Msd 6al box is mounted. Just getting into some wiring. Ended up putting a low resistance hei bushing in the distributor (was recommended I do so). Removed the hei module. I needed keyed power to turn the msd box on and off, I ended up removing the resistor wire and pin from the bulkhead and soldered a 12 guage wire to the pin and put it back in the bulk head, this way I have full 12 volt not 8 or 9.
I'm going from a 3 wire alternator to a 1 wire. In what way do I hook this up so that my ammeter still functions? Or will it function with just the 1 wire?
  • Keep em alive
« Reply #155 on: June 18, 2023, 08:25:05 pm »
Pic
Offline Chevynut73
« Reply #156 on: June 30, 2023, 08:40:05 pm »
WOW - great build!
You are fixin to have one nice C10  :)
Are those 10" Cragar's on the rear?
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
  • Keep em alive
« Reply #157 on: June 30, 2023, 08:45:55 pm »
The rear rims are 15x8. But the 295/50 fits nice on them
  • Keep em alive
« Reply #158 on: June 30, 2023, 09:07:08 pm »
Did what I can for wiring, time to put the nose on to keep going. Will take a little bit.  Frostbite electric fans are in the mail, that match the radiator I have
Offline Chevynut73
« Reply #159 on: June 30, 2023, 09:17:47 pm »
Is that right - that 295/50 looks a lot better!
I have 15x8 Rally's that looked fine with the Fleetside but not so good with the Stepper!
