Engine/Drivetrain
Th400 vacuum line
Topic: Th400 vacuum line (Read 5175 times)
Rzaszutak
Th400 vacuum line
January 13, 2023, 02:04:17 pm »
Hello guys, so I’m doing a resto mod on a 76 c10 and I was wondering where the transmission vacuum line connects to on the engine. I’m not use to working on gas engines
TIA
Re: Th400 vacuum line
January 13, 2023, 06:34:46 pm »
Manifold vacuum, on the tee at the back of the intake.
Rzaszutak
January 13, 2023, 06:36:22 pm »
Ok, I don’t have a tee because the engine was rebuilt at a shop. What does the other part of the tee go to?
January 13, 2023, 06:51:28 pm »
It's just a manifold vacuum tap, all depends on what you are running for vacuum accessories. Wherever you tap in, you need full manifold vacuum not ported.
Rzaszutak
January 13, 2023, 06:55:39 pm »
Ok thanks, one more question lol. I have never worked with a carb before so what ports do I hook the distributor vac line to and the vapor line to? And also the valve cover breather line?
January 13, 2023, 07:06:13 pm »
It depends, most people run full vacuum to the distributor advance with aftermarket performance parts unless they are trying to be emissions compliant. Canister purge is usually timed and ported but not enough info on your setup to be specific.
Rzaszutak
January 13, 2023, 07:07:54 pm »
I have a 454 with a brawler carb, and GM performance distributor
Engine/Drivetrain
Th400 vacuum line
