Author Topic: Rear Suspension install - tips - order of things  (Read 9125 times)
Offline 76Texan
  • 76 Scottsdale Owner
« on: January 18, 2023, 10:07:55 pm »
Hey all,
So a bit of a noob. This old farm truck, 76' K10, I decided to keep stripping and try and refurbish everything I can. The rear suspension went well, I will need brakes lines from the main line to the brakes. I put the KBS frame coat on it (up to the tranny- will finish the front once  I pull engine) after taking off as much rust as possible. Some of the parts I am fully de-rusting, like the leaf springs, brake parts, etc. I needed new shackles as well.
Any tips or good vids already on the order of installation here or any good what not to dos? So far all has gone well.
Thanks in advance.
1976 Scottsdale K10
Offline Shifty
  • I bleed Bowtie red...
Re: Rear Suspension install - tips - order of things
« Reply #1 on: January 19, 2023, 08:04:22 am »
Looks like you're doing it right thus far.   ;D
98 C2500 ext cab longbed
Offline 76Texan
« Reply #2 on: January 19, 2023, 02:36:04 pm »
Oh, I'll be in trouble at some point, It really needs the under-cab supports replaced, was not going to take the cab off but will need to. Will post photos on that later.
1976 Scottsdale K10
« Reply #3 on: January 19, 2023, 02:46:15 pm »
Oh, I'll be in trouble at some point...
That's good!  If you never get into trouble you're not doing anything!!   ;D
« Reply #4 on: January 19, 2023, 05:46:05 pm »
Why do you have thew driveshaft slip yoke at the rear axle?
Offline 76Texan
« Reply #5 on: January 19, 2023, 11:21:43 pm »
HUH. Please clarify. I did not change anything or do anything to the drive shaft other than clean/paint. I did clean out the rear end and changed one of the large washers and that pin but kept it where it is intact.
1976 Scottsdale K10
Offline Shifty
« Reply #6 on: January 20, 2023, 08:08:46 am »
I wasn't looking at that, but Vile is right! (surprising, I know), it looks like your driveshaft is "backwards".
Offline 76Texan
« Reply #7 on: January 20, 2023, 12:53:28 pm »
LOL, well good to know it's wise to post photos here. That's how it gave running and I did not notice at all. Funny. I know what I'm doing next. THANKS folks.
1976 Scottsdale K10
Offline JohnnyPopper
  • Old Goof
« Reply #8 on: January 20, 2023, 02:47:46 pm »
Good eye VZ!
Nice work BTW! Look forward to more!
1980 C-10 under construction
