Author Topic: 4L60 E rebuild.....  (Read 4089 times)
Offline Stewart G Griffin
4L60 E rebuild.....
« on: January 24, 2023, 09:15:53 pm »
Ballpark, how much do 4L60 E rebuilds generally cost?
This is if a decent shop is doing it; i'm not going to attempt this at home, kids.
Also, let's talk about 4L60's in general / anything else i should know about?
The 4L60 E in my colorado has crapped out, because-----you guessed it----the 3/4 clutch pack is toast.....
Re: 4L60 E rebuild.....
« Reply #1 on: January 25, 2023, 04:52:08 pm »
I would charge more than you would pay for a reman unit. They generally cost whatever the builder estimates which is a wide range.
« Reply #2 on: January 25, 2023, 09:20:21 pm »
i've heard that remans are often cheaper and faster than rebuilding.
i've also heard that the 4L60 E in the colorado is specific to the vehicle, so rebuilding may be the only practical way?
Do torque converters normally get replaced or flushed during a rebuild?
« Reply #3 on: January 26, 2023, 04:26:22 pm »
Estimated overhaul with new torque converter, I would charge $3150, does not include R&I and fluids etc. So I'm sure you would find cheaper options with a reman and yes always replace torque converter.
Offline peewee0413
« Reply #4 on: January 28, 2023, 02:35:39 pm »
https://www.performabuilt.com/product/level-1-street-cruiser-4l60e/
I use the Heavy Hauler, 2400 stall, and  US Shift Quick 4 on my 93 with a built 350 with aftermarket Fuel Injection.
Performabuilt makes one heck of a transmission.
Burnt up two 3rd clutches before buying a Performabuilt.
Sent from my SM-S908U using Tapatalk
