Author Topic: Transmission shifting wrong after carb spacer install  (Read 7038 times)
Offline benracing123
« on: January 27, 2023, 11:14:51 am »
I installed a 4 barrel carb spacer trying to boost my cfms a drop, however now my transmission shifts at 3k rpm under partial throttle, anyone have any idea h I could be
Re: Transmission shifting wrong after carb spacer install
« Reply #1 on: January 27, 2023, 01:07:54 pm »
I am going to assume you have a 700R4 transmission.  You changed the geometry of the TV Cable.  That needs re-adjusted.
« Reply #2 on: January 27, 2023, 04:09:02 pm »
It is
I don’t exactly know what the tv cable is but I’ll find it
« Reply #3 on: January 27, 2023, 05:44:48 pm »
I only have 1 cable to my carb linkage and it’s my throttle
« Reply #4 on: January 27, 2023, 05:51:15 pm »
Isn’t there supposed to be another cable next to the return springs?
« Reply #5 on: January 27, 2023, 06:21:43 pm »
Show us a picture of what transmission you have. If there's no cable it's a TH400
Offline PapaDG
« Reply #6 on: January 27, 2023, 07:04:30 pm »
There should be a button to press behind the metal bracket on that black cable on top. You’ll have to test drive it once you adjust it and make adjustments as necessary so it doesn’t throw through all gears immediately.
89 suburban v1500 stroker
« Reply #7 on: January 27, 2023, 07:22:40 pm »
This ^^^^.
Also, when you installed the spacer, did you unplug any vacuum lines and neglect to reconnect them?
Offline JohnnyPopper
  • Old Goof
« Reply #8 on: January 27, 2023, 07:30:26 pm »
I'm more interested in the spacer  ;)
What's the theory?
1980 C-10 under construction- GONE!
« Reply #9 on: January 28, 2023, 08:02:02 am »
What's the theory?
50 horsepower man. Now put magnets on your fuel line for another 10-20 mpg!
Offline Shifty
  • I bleed Bowtie red...
« Reply #10 on: January 28, 2023, 09:01:36 am »
What's the theory?
And stickers....don't forget stickers....
98 C2500 ext cab longbed
  • Old Goof
« Reply #11 on: January 28, 2023, 04:50:34 pm »
Hey Ben, I think we've been diss'd hard  :(
