Body, Glass & Paint
Boom Mat
Topic: Boom Mat (Read 7985 times)
MY1978
Just a girl and her truck since 1978
Boom Mat
February 21, 2023, 07:01:22 pm »
Thinking of using the spray-on Boom Mat on the underside of my hood. Comments? Anyone ever done this?
Re: Boom Mat
February 21, 2023, 07:23:24 pm »
I would suggest the oe style insulation or nothing.
MY1978
Re: Boom Mat
February 21, 2023, 07:32:03 pm »
I bought an OE style type and a mouse decided that it would make great bedding material from the back of the mat and there were a lot of acorn shells between the hood and mat. Going to have to take the mat out and buy an new one as it has holes in it and is tearing apart. Wasn't crazy about this mat anyway.
Da67goatman
Site Supporters
Burban
Re: Boom Mat
February 21, 2023, 08:58:47 pm »
What are you trying to accomplish?
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
MY1978
Re: Boom Mat
February 22, 2023, 06:03:25 am »
Well, from everything I have read, there should be something to protect the hood paint from getting so hot and damaging the paint. It is just a thought but open to other suggestions. Maybe the heat mat like you put on floors only for the hood?
Da67goatman
Site Supporters
Burban
Re: Boom Mat
February 22, 2023, 07:29:34 am »
Honestly, I have never seen paint affected by underhood heat (except Vipers) and I have always removed the insulation from every vehicle I've owned. I think your chasing a problem that doesn't exist. Anyway, a solution could be a high ceramics paint or a foil type mat on the underside to reflect the heat back down.
https://geni.us/heat-barrier
https://lizardskin.com/heat-protection/
<Pitcrew>
MY1978
Re: Boom Mat
February 22, 2023, 07:36:48 am »
ok, thanks. I just thought it was there originally for a reason so it needed to go back. Maybe I will just use some paint that can take the heat and spray the whole underside black.....so it is a consistent color.
Shifty
I bleed Bowtie red...
Re: Boom Mat
February 22, 2023, 08:39:50 am »
I have Dan, but....AZ. Things get mighty warm in the summertime.
98 C2500 ext cab longbed
Scott91370
Re: Boom Mat
February 23, 2023, 01:49:23 pm »
Older paint jobs and bad paint jobs do suffer from the heat. I've seen a few with cracking paint.
I did the factory style just because the under side of the hood is so ugly. Boom mat and dyna mat type things would be way overkill and weigh too much.
Mr Diesel
Aaron
Re: Boom Mat
February 23, 2023, 11:01:31 pm »
I have read that the primary purpose for underhood mat is fire suppression. They are generally made out of charcoal impregnated fiberglass, with the idea being a fire under hood melts the plastic retainers and the mat drops to help smother the fire. Never looked into it much but makes sense.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Body, Glass & Paint
Boom Mat
