Detent Kick down cable
Topic: Detent Kick down cable (Read 4474 times)
JohnnyPopper
Old Goof
February 21, 2023, 07:08:12 pm »
Bought one and ready to install, wrong one, though two sources I checked show this cable as correct.
1980 C10 5.7 CID TH350 (to the best of my knowledge)
My existing cable has a z-bend at the end, this one has a hole on the end.
TIA for your help!
1980 C-10 under construction
Re: Detent Kick down cable
February 21, 2023, 07:20:34 pm »
Your cable has a z bend? CA1951 @ O'Reilly is the correct cable.
⌠ŻŻŻŻŻ' [☼===☼]
JohnnyPopper
Old Goof
February 21, 2023, 07:31:22 pm »
Yeah weird!
I'll snap a pic.
The cable you site is like the one I have...
JohnnyPopper
Old Goof
February 21, 2023, 07:59:19 pm »
Here it is
February 21, 2023, 08:20:40 pm »
That's not your cable bud. The cable connects to the linkage.
⌠ŻŻŻŻŻ' [☼===☼]
MIKE S
Member
February 21, 2023, 08:25:02 pm »
That is correct. That sticks out of the case and goes thru the hole in the cable.
JohnnyPopper
Old Goof
February 21, 2023, 08:43:14 pm »
So it's a short piece of wire that has a hook for the islet on the end of the cable?
I guess that would make sense, beats having to drop the pan to change out.
I will keep you posted, Thanks!!!
