Author Topic: 3/4 ton engine options - repost  (Read 5165 times)
Offline chronos
« on: February 28, 2007, 01:27:00 pm »
I am looking at a 1986 3/4 ton. Did these come with a 400 engine? Is there a EASY way to tell a 400 from a 350 engine?? Thanks
Re: 3/4 ton engine options - repost
« Reply #1 on: February 28, 2007, 03:39:00 pm »
No they were no longer making the 400 in 1986. The best way is to read the casting # on the back of the engine near the bellhousing.
The 400 was used from 1970 -1980 and they only made 4 bolt mains in 71 and 72 if I remember correctly.
Look for the casting #'s
Also take a look at the balancer on the crankshaft. It will not be smooth all the way around you will see it is balanced.
Some say look to see if it has 2 or 3 core plugs on the side but I forget exactly what that reveals. I haven't owned a 400 in about 10 years.
Offline chronos
« Reply #2 on: February 28, 2007, 04:50:00 pm »
Thanks , Can I put the rearend from a 3/4 fullsize into a 1/2 ton shortbox?
« Reply #3 on: March 01, 2007, 07:53:00 am »
3/4 and 1/2 ton axles are the same as far as the bolt in dimensions. The ujoint will require a crossover joint.
different
« Reply #4 on: March 01, 2007, 03:35:00 pm »
The 3/4 ton will have 8 lug axles and different brakes.
Offline Fast68
Re: different
« Reply #5 on: March 15, 2007, 05:10:00 am »
the non 1 tons were all 42.5" leafpack spacing
1 ton were 40
1/2 and 3/4 interchange, same width
good luck
