Author Topic: how to remove rear door glass on a squarebody suburban or crew cab  (Read 11553 times)
Offline G-NUT
I have a 1984 C10 Suburban.  The rear driver's side door glass is cracked.  I recently bought a replacement from a salvage yard.  It was already pulled when I got there.  Now I'm ready to replace glass but I cannot find any information on the proper way to remove / install the glass.  I've replaced door glass before, just not on a C10.
Offline G-NUT
Re: how to remove rear door glass on a squarebody suburban or crew cab
« Reply #1 on: April 03, 2023, 03:24:34 pm »
how do you remove the rear passenger door glass on a squarebody suburban or crew cab?
« Reply #2 on: April 03, 2023, 03:43:05 pm »
Power or manual? Remove the door panel, unbolt the guide channel, unbolt the regulator to allow it to disengage from the glass sash. Rotate and lift out. It is sometimes better to remove the rubber/felt from the door as well. Some masking tape is a good idea so you don't scratch anything.
Offline G-NUT
« Reply #3 on: April 03, 2023, 06:50:35 pm »
Thanks for the info.
It's power window.  I've had to replace one of the front window power motors.  I've not taken the rear door panel off yet.  I was just observing it and it looked like I might have to remove the quarter glass to get the window out, but I'm hoping not.
« Reply #4 on: April 05, 2023, 09:58:57 am »
yes you will need to remove the quarter glass to get the main one out.  It is not that difficult
Offline G-NUT
« Reply #5 on: April 06, 2023, 09:59:13 am »
Thanks for the response.  I don't suppose there's any tips / tricks to getting the quarter glass out and reinstalling it?
Offline G-NUT
« Reply #7 on: August 11, 2023, 01:55:39 pm »
Did you look on the manual page in the Tech section?  http://forum.73-87chevytrucks.com/smforum/index.php?topic=30115.0
Specifically: http://www.73-87chevytrucks.com/techinfo/7387CKMans//Service/X8432_1984_GMC_Light_Duty_Trucks_Service_Manual.pdf#page=1679
Nope.  Hadn't found that manual.  Thanks for the link.
 :) :)  Thankfully I got it done!   With the help of your comment from April 5th and this thread from the other forum I got it done in late May.  https://67-72chevytrucks.com/vboard/showthread.php?t=743445
