Author Topic: Carburetor idling too high after new fuel pump  (Read 8390 times)
Offline Bullwinkle
« on: April 05, 2023, 01:02:23 pm »
After replacing my mechanical fuel pump the old Quadrajet carb is idling way to high.  I would guess around 2,200 rpm.  With the adjustment screw backed all the way off.  This is a 79 350, all original.  The pump is the same as the one I took off except its a little later model, with the return line to the tank, for vapor lock protection.  I'm thinking I should put a pressure gauge on the supply line going to the carb.  I guess that means putting a T in that line?
Many thanks.
Re: Carburetor idling too high after new fuel pump
« Reply #1 on: April 05, 2023, 03:44:01 pm »
Make sure that the choke fast idle cam isn't stuck on the high step.  Then use some aerosol carburetor cleaner and spray for vacuum leaks.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: April 05, 2023, 06:53:36 pm »
Do you have a return line?
Having one in the first place would suggest that there is an internal pressure regulator that routes gas back to the tank when not consumed by the carb/engine.
Or it just runs a higher volume to provide gas to the carb and return line.
So if you don't have a return line that may be the problem.
Why didn't you get a correct model?
A pressure test would tell you a lot, and yes, you can tee the line between the pump and carb.
1980 C-10 under construction
« Reply #3 on: April 05, 2023, 10:10:22 pm »
JP, the mechanical fuel pump with a return port incorporates a small diameter restriction in the return nipple of the pump to limit the volume of fuel returning to the tank(s).
How?   :D
Offline rodnrudy
« Reply #4 on: April 06, 2023, 08:51:25 am »
  Make sure you haven't inadvertently pulled a vacuum line off somewhere. That will cause a high idle.
  • Old Goof
« Reply #5 on: April 06, 2023, 12:48:27 pm »
bd I know you're having fun with me, but assuming the pump has a return tube and there is no return line to the tank, what else is he going to do but cap it off?
Please enlighten us  ;)
« Reply #6 on: April 06, 2023, 04:17:48 pm »
Well, hypothetically, let's say the return line is capped off, ... or not.  How might either result in a high idle on a carbureted engine?  :)
« Reply #7 on: April 06, 2023, 07:06:06 pm »
You probably knocked the choke wire off or a vacuum line popped off.
Offline Bullwinkle
« Reply #8 on: April 06, 2023, 07:16:43 pm »
Thanks for the great suggestions, I’ll check the choke.  It idles the same speed hot or cold, so I didn’t check it but yes it could be stuck all right.
Yes there’s a return line to the tank, that’s why I got that type.   I heard a guy say it worked well for him without any modification of anything else.
I don’t see how a return line could increase pressure unless the pressure is set higher on the supply line than on the older two-line pump.
   If I do end up putting in a gauge, what pressure would that original quadrajet use?
Thanks again very much
Offline Bullwinkle
« Reply #9 on: April 06, 2023, 07:21:35 pm »
The reason I put in the later 3-port pump was the reason they designed it in the first place.  Returning some fuel to the tank continuously keeps it from getting hot enough to vapor lock.
Offline Rapid Roy
  • Euless, Texas
« Reply #10 on: April 06, 2023, 09:51:55 pm »
X2
Should always replace parts that are designed for the year and model, especially if it is original engine!
« Last Edit: April 06, 2023, 09:55:18 pm by Rapid Roy »
Mopar by Birth
Chevy by Choice
« Reply #11 on: April 06, 2023, 10:19:14 pm »
For the 1979 model year trucks, small block fuel pressure for engines using a return line is 5 1/2 - 7 PSI; small block engines without a fuel return line call for 7 1/2 - 9 PSI.  Big block engines with a fuel return line call for 7 1/2 - 9 PSI.
Bullwinkle, fuel pressure isn't the cause of the high idle complaint.  Most likely either the choke isn't releasing or air is bypassing the throttle (e.g., a vacuum leak).
JP, I was just trying to lead you to think the symptoms through.  I know you have the knowledge and experience.   :)
« Last Edit: April 06, 2023, 10:21:14 pm by bd »
  • Old Goof
« Reply #12 on: April 06, 2023, 10:49:49 pm »
bd=mentor
Thanks!
