Author Topic: Fire wall wire tray  (Read 10318 times)
Offline Swampyankee74
  • Keep em alive
Fire wall wire tray
« on: May 12, 2023, 01:18:19 pm »
I'm having a hard time finding a place to purchase a new wire holder that goes along the top of the firewall. Does anyone know where I can find this? For a 1974 gmc c1500
  • Keep em alive
Re: Fire wall wire tray
« Reply #1 on: May 12, 2023, 01:19:24 pm »
Pic
Sent from my SM-S515DL using Tapatalk
Offline Mike81K10
« Reply #2 on: May 12, 2023, 07:10:43 pm »
I got one from a salvage yard. You may find one this is not necessarily from your model vehicle. Other vehicles may have one that will work if you look around.
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: May 12, 2023, 07:12:03 pm »
Mike is pry right, but I really doubt you'll find a stock replacement.
You can use the corrugated plastic tube with a split.
While you're at it, lower the entire harness to follow the sheet metal going over the bell housing.
Will be a lot cleaner, cause that is just UGLY... ;D
1980 C-10 under construction
« Reply #4 on: May 12, 2023, 07:30:48 pm »
As far as I know, they are not and never were reproduced. My 74 looked like that too and I tossed it 25 some odd years ago. 73-74 were the long ones and after that I'm pretty sure they went to the short one for the remainder of the years. Since yours is all thereish you can reproduce it or try and repair it.
  • Keep em alive
« Reply #5 on: May 12, 2023, 07:46:04 pm »
Thank you all. Mine is still functional, not torn or anything.  Just between heat and gravity it looks like shoot. I'll probably throw it in parts pile and go with corrugated. Was just hoping someone made a direct fit part
« Reply #6 on: May 13, 2023, 08:06:05 pm »
Clean it real good and glue it to a thin metal strip so it doesn't look like it's melting in and I bet it will look mint.
  • Old Goof
« Reply #7 on: May 13, 2023, 08:38:14 pm »
Now that's an idea VZ!
OEM all the way!
  • Keep em alive
« Reply #8 on: May 13, 2023, 09:18:27 pm »
That is a good idea, a little reinforcement
Offline mcarter
« Reply #9 on: May 14, 2023, 01:59:05 pm »
Think they are called a wire gutter, there's one on eBay now and several of the truck parts folks show them in catalogs.
Offline Mr Diesel
  • Aaron
« Reply #10 on: May 14, 2023, 04:26:40 pm »
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
  • Keep em alive
« Reply #11 on: May 14, 2023, 04:42:57 pm »
That would work. Looks like could cut and drill to fit
« Reply #12 on: May 14, 2023, 04:57:26 pm »
The 67-72 version might be the closest thing to it
  • Keep em alive
« Reply #13 on: May 14, 2023, 08:15:43 pm »
I will check that out also! Thank you!
