Author Topic: Edelbrock 1406  (Read 39095 times)
Offline JohnnyPopper
  • Old Goof
Edelbrock 1406
« on: May 13, 2023, 02:41:21 pm »
For a '78 K10 350 CID
Any thoughts on this? I see some pretty good reviews, more pro's than con's.
Need to do something about gas mileage... ::)
« Last Edit: May 13, 2023, 03:06:46 pm by JohnnyPopper »
1980 C-10 under construction
Offline Mr Diesel
  • Aaron
Re: Edelbrock 1406
« Reply #1 on: May 13, 2023, 03:34:52 pm »
I've been running one on a 305 in a Camaro for about 13 years now. It is decent, was pretty easy to tune, stays tuned, reliable. The biggest complaint I have about it is the heat soak and hot restart. Shut it down hot and dont restart within 5 minutes and it floods. Have to hold pedal to the floor to restart. Annoying, but I explored all other alternative fuel systems and pretty much decided they ALL have their cons.
Got another in a 1983 K30 on a 454. Never had the hot restart problem on it, probably due to the much more spacious engine bay to allow heat escape.
I dont think I would ditch a stock fuel system for the 1406 though. In my case the 305 and 454 lost their quadrajets long before I owned them. All fuel injection systems have their down sides too, but if they were still intact I think I would keep them working. Change isnt always better.
« Last Edit: May 13, 2023, 03:38:27 pm by Mr Diesel »
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
  • Old Goof
Re: Edelbrock 1406
« Reply #2 on: May 13, 2023, 05:48:38 pm »
Understood, thanks!
I've been a Qjet fan for decades, in rebuilding them I've never thought I got it perfect but close.
The rebuild shops around here don't want to touch them, and recommend the 1406.
Maybe I could find a shop somewhere else in the country that has the task down pat.
Offline Mike81K10
Re: Edelbrock 1406
« Reply #3 on: May 13, 2023, 07:45:12 pm »
I have one! It flooded so bad that fuel flowed all over. I went back to my Rochester and had no problems.
Re: Edelbrock 1406
« Reply #4 on: May 13, 2023, 08:09:29 pm »
Hot restart is definitely a known issue but can be resolved with correct fuel pressure and a heat insulator base.
  • Old Goof
Re: Edelbrock 1406
« Reply #5 on: May 13, 2023, 08:41:17 pm »
Good feedback guys! thanks!
Comes down to fuel economy-Will the Qjet win or EB?
I know there are variables, but in general... ;)
Re: Edelbrock 1406
« Reply #6 on: May 14, 2023, 04:50:41 pm »
Q-jet will give better fuel economy
Offline Mike81K10
Re: Edelbrock 1406
« Reply #7 on: May 14, 2023, 08:14:58 pm »
Why is fuel economy an issue? I am not trying to be mean, so please forgive me if I say the wrong thing. I don't believe anyone would have a 73-87 Square body if they are really concerned with fuel economy. I am more concerned with my truck running well. I don't see modifications making much of a difference unless you go to an electric motor kit.
Re: Edelbrock 1406
« Reply #8 on: May 15, 2023, 02:58:32 pm »
Smiles per gallon
  • Old Goof
Re: Edelbrock 1406
« Reply #9 on: May 15, 2023, 05:34:13 pm »
To drive a square? That's a lot of money for gas!  ;D
I don't think you're being mean, I see yours and VZ's point. It's more the experience, and yes, the smiles and thumbs up.
She's my daily, and growing up in the '70's we were conditioned to stretch out the mpg starting in auto shop.
Keep it as well tuned as possible and the tires inflated!
BTW, found a outfit that sells rebuilt and flow tested QJet, going to call them. AND for a lot less than the EB
Thanks guys and gals!  ;)
  • Old Goof
Re: Edelbrock 1406
« Reply #10 on: May 18, 2023, 02:05:00 pm »
While I'm at it I may as well consider a better intake manifold.
Sadly I have to keep an EGR option available.
Any suggestions? TIA!
Online Shifty
  • I bleed Bowtie red...
Re: Edelbrock 1406
« Reply #11 on: May 18, 2023, 03:32:51 pm »
Tough to beat the Edelbrock Performer for a dual plane, either the 2701 or 2601 IMHO.
98 C2500 ext cab longbed
Online bd
Re: Edelbrock 1406
« Reply #12 on: May 18, 2023, 03:34:27 pm »
Other than saving weight and dressing the engine with a "performance look" for $$, without a camshaft, higher flowing heads, and exhaust upgrades, there will be virtually no perceivable benefits.  Otherwise, if you are bored and simply anxious to change something, Edelbrock or Weiand.  Or, perhaps, a nice roots blower peeking out through the center of the hood...   ;D
  • Old Goof
Re: Edelbrock 1406
« Reply #13 on: May 19, 2023, 08:49:54 pm »
Thx guys!
Too bad I live in a state that sucks the money out of old car/truck owners to control smog that doesn't existing anymore.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Edelbrock 1406
« Reply #14 on: July 23, 2024, 01:07:39 am »
I've had a lot of 1406's  On a 69 mustang with a 302, 77 C10 with 350, now currently on my 78 C20.   I think the QC as gone to crap.   5 or 6 years ago on my C20 I found I had a vacuum leak coming from the throttle shafts being loose fitting.   okay fine I'll replace it.   I got another 1406 to replace is from the local speed shop open box so I couldn't return it...  Brand new in the box it had the exact same loose throttle shaft vacuum leak my old carb had.
So I went back to the store and told the guy what had happened.  I knew I couldn't return it and didn't even try.   ya know.  I just wanted to know...  I asked him could we go through some of the boxes of other 1406 carbs he had in stock and he said yes.  they all had the loose throttle shaft.   If I had known that I'da sent my old one out and had it repaired instead. That was 6 or 7 years ago.   I love Edelbrock carbs.  know how to tune them and i have all the parts n pieces to do it.  They are the carb I know how to tune the best.  If you buy a new one and have minor vacuum problems with it check the throttle shafts for loose fit.  if you go to buy a new one go in person and check the shafts for loose fit.
