Author Topic: Idler Arm and Pitman Arm Torque Specs  (Read 9532 times)
Offline LILT77
« on: June 20, 2023, 09:16:10 pm »
Looked through the FSM, maybe Im blind. Replacing the idler arm and pitman arm. Does anyone know the torque values associated with these parts? Idler arm to frame mount/center-link, pitman arm to gearbox/center-link?
77 C10/Big 10 Cheyenne "Old Blue"
81 C2500 Sierra Grande "Gramps"
Offline JohnnyPopper
  • Old Goof
Re: Idler Arm and Pitman Arm Torque Specs
« Reply #1 on: June 21, 2023, 11:45:27 am »
Mostly depends on the size of the bolt/nut/thread count. I'm sure there is a torque guide on line.
The ball joints of those components go as tight as you can to get the cotter pin to line up.
1980 C-10 under construction
« Reply #2 on: June 22, 2023, 05:57:52 am »
Pitman arm nut to gear box is 185 ft-lbs, pitman arm to relay rod is 66 ft-lb, idler arm to frame is 30 ft-lb, idler to relay rod is 66 ft-lb.
