Author Topic: Fuel Cell Install in the Bed  (Read 18586 times)
Offline Chevynut73
« on: January 09, 2024, 10:20:23 am »
After taking the '73 from a long bed to a short bed, i had to remove the original fuel tank and don't really want to install a short bed 16 gal tank in the frame so would like to install a fuel cell in the bed.
My question is  -  Do i need to/have to hook up the RETURN LINE to the canister under the hood ?
Thanks
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
Re: Fuel Cell Install in the Bed
« Reply #1 on: January 09, 2024, 10:48:56 am »
Your fuel pump will have a return line so yes.  To get rid of that you would have to run a electric pump/regulator in the tank set to the ideal 5-7lbs that your carb wants.
This is assuming you are just changing tanks.
« Reply #2 on: January 09, 2024, 04:05:19 pm »
Why would you want a fuel cell in the bed? Just replace the tank
Offline Chevynut73
« Reply #3 on: January 16, 2024, 12:38:21 pm »
Thanks for the info, i will go ahead and run the return line.
VZ - your answer is in my post, thanks.
« Reply #4 on: January 16, 2024, 03:20:56 pm »
Because you didn't really want to. I got that much ;D
Offline Chevynut73
« Reply #5 on: January 22, 2024, 06:42:26 pm »
VZ - the short bed fuel tanks are 16 gal. correct?  That's too small.
Do not want to cut up the bed or frame braces anymore than we already have, so a between the frame fuel tank is not a good option.
Installing a fuel cell/tank in the bed is a good option.
You have any ideas?
Offline Mike81K10
« Reply #6 on: January 22, 2024, 07:33:45 pm »
LWNB trucks also have the 16 Gallon Saddle tanks. I have two that came OEM with my truck. The rear tank that some installs in the frame rails (back of truck) carries more than 16 gallons. You need a vent line to the canister, it is for vapor and can prevent vapor lock. VZ or someone else may have another idea. I am just going by the OEM setup.
« Reply #7 on: January 24, 2024, 04:19:52 pm »
Since 1990's I have swapped alot of my 73-87 trucks to the Blazer/Jimmy tanks in the rear frame..   I wrote this YEARS ago... http://www.captkaoscustoms.com/blazertank.html
That is a 31 gallon tank and it is in that truck and my current twin turbo truck documented here: http://forum.73-87chevytrucks.com/smforum/index.php?topic=12120.msg190717#msg190717
LWB trucks could be had with 20gallon pairs, 20gallon single, 20 and 16 gallon, or in some rare (cannot prove original) instances 16 gallon pairs although the later I question as all the documentation I have says standard LWB tank was 20.
SWB trucks were only available with 16 gallon pair or a single 16.
You want find a 31 gallon fuel cell and everyone i know that used one had horror stories on a daily...
Offline Mike81K10
« Reply #8 on: January 24, 2024, 10:11:33 pm »
Perhaps the original owner of my truck ordered it with the two 16 Gallon tanks. I am the second owner and I got it with low miles (about 60K I believe) and all original. The owner carried a camper in the bed. He pulled it out and put it into a new truck he bought. The original color was baby blue with a blue interior. Shortly after getting it I had to get the transfer case rebuilt.
« Reply #9 on: January 25, 2024, 05:11:09 pm »
Dual tanks are bolt in and the Blazer tank conversion is another option. If you only have one gas door/hole, there are ways around that as well. I wouldn't give up your bed space for a fuel tank unless this is a race truck. One 16 gallon tank means more pit stops to gas up and have everyone drool over your truck too  8)
