Author Topic: Where can I order this hose?  (Read 6758 times)
Offline dez81
« on: March 19, 2007, 08:41:00 am »
Does anyone know where i can order a fuel filler hose from for an 81 C-10 stepside? I need one pretty quick and none of the local parts stores here have anything. I've checked some of the other places like   but no luck.
Offline 123 pugsy
fuel hose
« Reply #1 on: March 19, 2007, 06:09:00 pm »
Check the dealer. If not you could use a pce of rad hose. Just look for a small one that has a nice bend in it and cut out the part you need. I've done this a couple of times.
Pugsy
76 C10 LWB
TPI 350
Re: Where can I order this hose?
« Reply #2 on: March 19, 2007, 11:57:00 pm »
I got mine from the dealer. Tried form Yankee GMC trucks but they had no clue and sent me the wrong stuff and then insisted that someone must have modified my truck. Ended up going to Benson Chevrolet in Franklin N.H., and they had the right parts in 2 days.
Offline dez81
« Reply #3 on: March 20, 2007, 12:35:00 pm »
I called the local dealerships and they told me GM no longer carries the parts it would have to be something fabricated. I hate to go to the junkyard because I'll like a new hose.
Offline warlok1469
« Reply #4 on: March 20, 2007, 01:00:00 pm »
Not sure which store but my friend picked up some by the foot from an auto parts store. Flexible with a coil in it. Worked perfevt for my side tanks. Maybe even home depot has it too.
If you kill a man, you're a murderer.....kill many, and you're a conquerer..... kill them all,..... YOU'RE A God!!
« Reply #5 on: March 21, 2007, 05:52:00 am »
I would call a bigger dealership, or one with a better parts dept. I just bought mine a few months back, and they had it from out of state whare house in two days.
Edited by: Blazin at: 3/21/07 4:53 am
Offline 123 pugsy
Hose
« Reply #6 on: March 21, 2007, 07:32:00 pm »
Like I posted earlier. you can have a hose bought and installed in about 2 hours.Just grab a small rad hose with a nice bend in it and you're good to go.Take your filler neck with you to get the right diameter.
Edited by: 123 pugsy at: 3/21/07 6:32 pm
Pugsy
76 C10 LWB
TPI 350
Offline dez81
Hose
« Reply #7 on: March 22, 2007, 08:26:00 am »
Thanks for the reply's. I'm going to check a few more options Fast68.
123pugsy is the filler hose and radiator hose made of the same material? I bought a makeshift hose from carquest but the guy said it was temporary. The last thing I want to worry about is if the fuel will burn a hole in the hose and possibly cause an explosion.
I don't know much about these things and just want to be sure.
Offline GMCTed
Re: Hose
« Reply #8 on: March 22, 2007, 06:27:00 pm »
when i restored my pickup with dual tanks i used a bed with only one fuel door so i got a radiator hose and put it from the tank to the wheel well 6 years ago without any problems so i doubt you`ll have any either.
Offline 123 pugsy
Hose
« Reply #9 on: March 23, 2007, 08:45:00 pm »
Ran one on my last truck without problems for 6 years. I believe they are the same material but not 100% sure.
Pugsy
76 C10 LWB
TPI 350
