Author Topic: 84 Jimmy Build  (Read 225313 times)
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #60 on: September 18, 2024, 04:51:10 pm »
Pretty slow progress over the past few weeks.  Work has been crazy and I've had no motivation.  I did get some grinding and dent pulling done, and I got this small piece near the driver rocker fixed.
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #61 on: September 19, 2024, 03:43:01 pm »
I wish all of the repairs were this easy...
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #62 on: May 31, 2025, 04:41:50 pm »
I lost interest for the past several months but now I'm back in the fight.  I've been taking care of a lot of little stupid things but finally got the courage to tackle the firewall.  I knew this was going to be painful and I was right
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #63 on: May 31, 2025, 04:45:31 pm »
Offline JohnnyPopper
  • Old Goof
Re: 84 Jimmy Build
« Reply #64 on: June 04, 2025, 06:40:55 pm »
I've probably said this before: You're a brave man!!!
1980 C-10 under construction
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #65 on: June 05, 2025, 11:18:40 am »
Thanks.  This is the last bit of rust so I should be able to put the welder and grinder away now.
Online VileZambonie
Re: 84 Jimmy Build
« Reply #66 on: June 05, 2025, 05:43:38 pm »
Choose work and success over couch. I've repaired much worse. You should see how my 75 Jimmy looked vs now. Git R done!
Keep chuggin man
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #67 on: June 30, 2025, 07:16:08 pm »
Finally started body work last week and forgot how bad the previous owners screwed up the jamb area on the driver side.  I got the gaps pretty good but they need some more work.  Here is the before and after of what I had to do to repair stupidity.  I'm amazed how much time people with spend repairing panels with bondo.  I'll have to rework the upper roof skin in the top right but that won't take long to fix and get the gap corrected.
« Last Edit: June 30, 2025, 07:22:01 pm by 1981lt1 »
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #68 on: June 30, 2025, 07:21:11 pm »
Online VileZambonie
Re: 84 Jimmy Build
« Reply #69 on: July 01, 2025, 07:27:51 pm »
Looking good dude  8)
  • Old Goof
Re: 84 Jimmy Build
« Reply #70 on: July 02, 2025, 05:01:02 pm »
Nice lines!
At current market prices, you won't lose money if you decide to sell.
BTW, glad you were able to eat some Frosted Flakes along the way...
Re: 84 Jimmy Build
« Reply #71 on: July 03, 2025, 11:06:45 am »
Nice work!
Offline Shifty
  • I bleed Bowtie red...
Re: 84 Jimmy Build
« Reply #72 on: July 07, 2025, 11:30:54 am »
Gaps look outstanding!
98 C2500 ext cab longbed
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #73 on: July 10, 2025, 07:16:09 pm »
I haven't replaced the body bushings yet but the fender gap looks pretty good.  I gotta do something about the A-pillar to door gap right above the fender though.  It's pretty nasty.
Online VileZambonie
Re: 84 Jimmy Build
« Reply #74 on: July 11, 2025, 07:43:41 pm »
Don't even fiddle with those gaps til you are sitting on your good body mounts.
