Author Topic: Alternator  (Read 14764 times)
Offline SILSquarebody
Alternator
« on: August 12, 2024, 07:33:47 pm »
I bought this 86 K5. It has a serpentine belt on the alternator. I dont believe that is stock. It is squeaking real bad. I need to replace it. Can I get a 105 Amp alternator like for a mid 80's camaro and change the pulleys on it from mine? Will that work ok? Thanks in advance.
Re: Alternator
« Reply #1 on: August 12, 2024, 09:27:31 pm »
17802 or CS130 conversion based on what connectors and wiring you have. You say its not stock possibly so putting in a high output generator with inappropriate wiring could cause fire/meltdown.
Re: Alternator
« Reply #2 on: August 14, 2024, 05:07:29 pm »
I dont believe the 86 had a serpentine belt did it? This has a serpentine belt for the alternator but a regular belt for ps pump. AC compressor has been removed.
« Last Edit: August 14, 2024, 06:54:29 pm by SILSquarebody »
Offline Shifty
  • I bleed Bowtie red...
Re: Alternator
« Reply #3 on: August 14, 2024, 05:16:34 pm »
Yes, that's stock.
98 C2500 ext cab longbed
Re: Alternator
« Reply #4 on: August 14, 2024, 06:55:15 pm »
Ok thanks.
