Author Topic: Throw-out bearing squeeking  (Read 4227 times)
Offline allhailacdc
« on: April 03, 2007, 04:32:00 pm »
I just put a brand new clutch pack in my 1976 Chevy K20. The problem is, when the clutch pedal is out all the way, the throw-out bearing is not backed off far enough from the pressure plate, causing a small squeeking noise. I have a spring on the clutch fork pulling it out more but it doesn't seem to work. Can anyone help me figure this out?
Re: Throw-out bearing squeeking
« Reply #1 on: April 03, 2007, 07:24:00 pm »
Does it go away when you depress the clutch pedal? Did you grease the pivot on the clutch fork before you installed it?
Offline allhailacdc
« Reply #2 on: April 03, 2007, 07:49:00 pm »
when it does squeek, which isn't all the time, it still squeeks when i press in the pedal, it goes away shortly, and it isn't very loud. i sure hope its not my throwout bearing cause it was pain in the arse to lift that tranny and tcase up. i did grease the clutch fork, i've noticed that my clutch pedal doesn't come completley up, i can pull it all the way up, and when i do, it doesn't squeek. in stock setups is there a spring connected to the clutch fork and frame to pull the throwout bearing away? thats the setup i currently have to try and keep it from squeeking. I might try a heavier spring to pull it further.
« Reply #3 on: April 04, 2007, 03:01:00 pm »
Did you grease the inner collar of the release bearing too?There is a recessed area on the collar that needs to be packed with grease also. If it doesn't go away when you depress the clutch it may need to come back out.
