Author Topic: Bought the wrong FJ Steering to swap out?  (Read 40447 times)
Offline juancano
« on: November 10, 2024, 12:18:33 pm »
Aaaargh!!! I guess I messed up. I thought I bought the right Jeep Steering to swap out on my 1986 C10, and I should've double-checked it before drilling an extra hole in it!!! #rookiemistake
Steering won't expand anymore. It stops about 3/4" short of the steering box shaft.
Gosh darn it!!!
Offline berserk
Re: Bought the wrong FJ Steering to swap out?
« Reply #1 on: November 11, 2024, 12:12:59 am »
About 8 years ago I went to the yard and meticulously chose my jeep steering shaft based on the research I had done. Went home and it wasn't even close 😆 I just replaced the rag joint and gave up.
If I remember correctly, the shaft on my steering box wasn't even close to fitting that one on the jeep shaft
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
Offline berserk
« Reply #2 on: November 11, 2024, 12:14:08 am »
Edit, I tried to used
 a JK shaft so not sure if that was the issue.
« Reply #3 on: November 11, 2024, 01:36:31 pm »
Do you mean XJ?
Offline berserk
« Reply #4 on: November 12, 2024, 04:51:32 am »
Yes lol I work 3rd shift and was out of coffee when I wrote that, it was an XJ. We had a row of them in the Pull a Part OKC years ago and I had the pick of the litter. I was disappointed when it didn't work out 😆 I just bought a new rag joint and called it good. But they don't make them like they used to and it dry rotted in under 15,000 miles.
Offline juancano
« Reply #5 on: November 12, 2024, 01:03:55 pm »
I gave up and based on a friend's advise I am just spending the money and buying the right Borgesson Steering shaft.
« Reply #6 on: November 13, 2024, 04:17:50 pm »
I do not like the Borgesen steering shafts.
Offline Shifty
  • I bleed Bowtie red...
« Reply #7 on: November 14, 2024, 01:08:46 pm »
Just curious, why?
98 C2500 ext cab longbed
« Reply #8 on: November 14, 2024, 04:58:01 pm »
Universal design with poor fitment, drilling and held in by set screws. It's ugly too. The XJ shaft is a much better design or stick with the OE shaft and rag joint. Just my opinion
Offline Shifty
« Reply #9 on: November 16, 2024, 04:33:59 pm »
OK, had to hear both sides... ;)
