Author Topic: TBI Burb dying in gear, My Turn.  (Read 96814 times)
Re: TBI Burb dying in gear, My Turn.
« Reply #90 on: June 12, 2007, 03:32:29 pm »
also I can't remember but did you say you checked the fuel pump relay?
« Reply #91 on: June 12, 2007, 03:44:45 pm »
Just rebuild yours it's wicked easy. Get a new pickup coil and module. Drive the pin out of the drive gear. If you look at the drive gear it has a dot on one side. That dot faces the same direction as the rotor on the pole piece. Take out the pole piece and replace the pick up coil. I usually wire wheel the pole piece and lube it with some engine oil but not too much.
yeah, I know, but I really don't want to, it is an option if I get into the mood to work on it again, figured this would be a good time to upgrade.  I may do that this weekend if I don't break down and get a new one...
have you tried to replace the ignition module with a known good one? I've had similar symptoms with vehicles I'v had in the past that a new ignition module cured.
My only knowm good one is in my DD, and I am definitely not pulling it apart.  With a new distributor, I would eliminate all issues with the distributor in one swing.
Yep, checked it.  It is getting plenty of fuel.  It does now have a nice occasional miss to it now.
« Reply #92 on: June 12, 2007, 08:29:34 pm »
The reason I say that is the relay can overheat. Take a jumper wire to the fuel pump test lead and bring it B+. that bypasses the relay and runs current directly to the pump. See if it still dies with the jumper wire on there.
Offline Toolmaster
« Reply #93 on: June 16, 2007, 08:52:29 pm »
 ;D I heard it through the grape vine !!! ;D  Chris is driving the Burb ????
Could it BE !!!!   He has killed the gremlins !
« Reply #94 on: June 16, 2007, 09:22:10 pm »
Hmmm, that would be me, so you really heard from the grape right?  :D
I just drove it all over my neighborhood and stopped at every stop sign.  Stayed running the whole time.  I am getting a code 44, but I have an idea where that is coming from.
After swapping the cap rotor and coil, the Burb developed a miss.  I had time today to look at it and pulled the distributor to rebuild it.  Afer getting it out the magnetic pickup was falling apart.  No one had that piece so I got a new distributor.  After getting it in, it is running good again.  Yippie.
In retrospect, I suspect that there was a barage of problems with this.  Short of replacing the MAP sensor, temp sensor and TPS, everything is new.
Pics to follow.
Offline DnStClr
« Reply #95 on: June 17, 2007, 03:12:38 pm »
Well this is great news! I s'pose it's too late to make that Maggie Valley thing?  ;D. Now if we can just find you a window..
Don
87 Chevy Silverado
« Reply #96 on: June 17, 2007, 07:49:00 pm »
Yeah, just a little late on that trip.  The company I got the window from Friday better get me a new one for free since this one was bullseyed in the corner when I got it...
Next on the list is the rotting tailpipe....
« Reply #97 on: June 17, 2007, 09:21:07 pm »
Cheese and Rice. So it was just a bad pick up coil... Well glad you got it straightened out!
« Reply #98 on: June 17, 2007, 09:58:33 pm »
The last part was the pickup (that is when the miss started), but I believe the bad injector was slowly dying, which was the cause.  I drove it some more today and still holding up fine.
Offline bigwinch1
« Reply #99 on: December 02, 2012, 10:07:32 pm »
Figured i would pop in i have just finished fixing this very same problem on my 87 R10 with the 5.7 in it i replaced everything and the truck was still doing this i pulled the distributor this weekend and the pickup coil was severely rusted was almost locked up i replaced distributor and set timing at TDC and the truck runs better than it did when i first bought it hope i was some help if you haven't gotten it fixed yet
                               Chris
                       Sorry just checked and saw you found the same problem i had glad you got it fixed
« Last Edit: December 02, 2012, 10:10:48 pm by bigwinch1 »
1987 Chevy R10
