Author Topic: Roller Grease (Grease compatibility?)  (Read 18881 times)
Offline IdahoMan
« on: May 16, 2025, 05:25:16 pm »
Quick question.
I'm following the bd's instruction to help with my sluggish power door windows.
-What type of grease was used on these truck's windows?
-Is there a method of determining an unknown grease type?
I have a canister of Super Lube Synthetic and a tube of Marine Grease (Calcium Sulfonate). Want to make sure whatever I use is compatible.
PS: Is there a test one can do to determine if two unknown greases are compatible?
Thank you,
IM
Online bd
Re: Roller Grease (Grease compatibility?)
« Reply #1 on: May 16, 2025, 06:51:34 pm »
Use a lithium base grease such as Sta-Lube General Purpose (greenish brown), Sta-Lube Sta-Plex (red), or Lubriplate Type A (white).  Super Lube Synthetic (clear) will work, too, but may need to be reapplied more frequently than the lithium base greases.  Generally, I do not recommend mixing greases that are known to be different.  Specifically, don't mix lithium base and calcium base greases - results can vary but often cause unpredictable changes in viscosity, lubricity and sometimes causes caking.  That said, the Sta-Lube General Purpose grease is probably most like the factory grease used during assembly.
