Author Topic: Are there any AV Home theatre "GEEK SQUAD" type folks?  (Read 41882 times)
Online zieg85
« on: May 17, 2025, 02:35:48 pm »
I purchased a new 75" Samsung TV and just assumed I could get analog audio out to hook up to my older 5.1 Yamaha for the audio only.  Can anyone shed some light on what I may need to do what I want.  Thanks in advance
Re: Are there any AV Home theatre "GEEK SQUAD" type folks?
« Reply #1 on: May 18, 2025, 05:01:53 am »
Most new TV's are Bluetooth and don't use the old school audio outputs. Is your receiver RCA input? What inputs does it have and what outputs does the TV have? You can use converters and even a BT receiver.
Online zieg85
« Reply #2 on: May 18, 2025, 07:19:20 am »
My receiver has RCA/S-Video inputs.  New TV has HDMI EARC and Optical port.  I did try a 1080P HDMI Male To 3 RCA Video Audio AV Component Converter Adapter Cable HDTV but it did not work.
« Reply #3 on: May 18, 2025, 04:56:29 pm »
The TV doesn't have BT audio ?
Online zieg85
« Reply #4 on: May 18, 2025, 07:26:53 pm »
Connectivity Options
HDMI 2.1   4
USB-A 2.0   2
WiFi5   Yes
Bluetooth 5.2   Yes
Ethernet / LAN   Yes
Ex-Link ( RS-232C )   Yes
Anynet+ ( HDMI-CEC )   Yes
Digital Audio Out ( Optical )   Yes
HDMI Audio Return Channel   eARC
HDMI Maximum Input Rate   4K 120 Hz ( For HDMI 1 / 2 / 3 / 4 )
RF In ( Terrestrial / Cable Input / Satellite Input )   1 / 1 ( Common Use For Terrestrial ) / 0
Online zieg85
« Reply #6 on: May 19, 2025, 06:42:45 pm »
Thanks VileZ!
Offline JohnnyPopper
  • Old Goof
« Reply #7 on: June 07, 2025, 11:20:40 pm »
Hey Zeig,
Sounds you're using the RF input on the TV as the source video, with audio back to your receiver? Or do you use outboard video sources, i.e. AppleTV, Cable or Satellite?
The BT device sends stereo, so will not deliver any surround sound encoded in the program.
Your 5.1 receiver most likely has a coaxial and/or optical input for multi channel playback. If only coaxial, there are optical to coaxial converters. Look for Vanco for options.
VZ's suggestion is a great solution, I will use it on car/truck applications. Thanks VZ!
1980 C-10 under construction
