Author Topic: Gas Station pump keep shutting off whil fueling  (Read 65442 times)
Offline IdahoMan
« on: May 24, 2025, 02:52:34 am »
It's very difficult to put fuel into my truck at the gas-station, and the last gas-station I was at I almost didn't manage to fuel it at all. The gas pumps constantly shut off. I try to angle the nozzle right, squeeze the trigger is little as possible, have it inserted at the right depth, and it's a constant acrobatics to maybe keep it running.
Is there something wrong with the truck or some dumb new tech with the pumps?
Thx.
Offline Rough75C20
Re: Gas Station pump keep shutting off whil fueling
« Reply #1 on: May 24, 2025, 07:43:03 pm »
Had my filler neck upside down which was causing this.
« Reply #2 on: May 25, 2025, 06:46:11 am »
You aren't flowing fuel into your tank fast enough to prevent fuel from being drawn into the safety valve on the pump. What is YMM of your truck? The fuel filler changed designs several times over the years and got larger with a larger vent. Do you have a functioning fuel tank vapor vent? If everything is as it should be and you have the earlier smaller filler, holding the nozzle upside down or further back helps. Also, don't go full throttle.
Offline Shifty
  • I bleed Bowtie red...
« Reply #3 on: May 26, 2025, 03:08:22 pm »
My DD OBS (7.4) has this same issue, but not at every station....
98 C2500 ext cab longbed
Offline IdahoMan
« Reply #4 on: May 26, 2025, 07:56:15 pm »
Sorry, it's a 1981 Silverado 3/4.
Don't know about the vapor vent.
Thanks for the tips.
