Author Topic: Sanding/buffing/polishing  (Read 36389 times)
Offline whipper.snapper
« on: June 30, 2025, 05:45:50 pm »
Hey yall, I have a question regarding polishing my paint.
My process right now has been to Sand the little bit of orange peel that I have starting with 800 or 1000 and ending on 2000 or 3000ish.
Following the sanding I start with 3M perfect-it rubbing compound with a foam pad on a rotary polisher, and then finish it up with the 3M perfect-it machine polish.
The problem: there will still be scratches showing after using the rubbing compound, do I need a more aggressive cutting compound? Do I need to go higher in sandpaper grit? Or do I just need more elbow grease and do more rounds of rubbing compound?
Also, if y’all wanted to let me know what your favorite cutting/polishing compound is that would be great. This is my first time.
Thank you in advance!
Re: Sanding/buffing/polishing
« Reply #1 on: July 01, 2025, 07:23:56 pm »
Contaminants and breakaways cause gouges and scratches. I only wet sand and use soap. It's very easy to get carried away and never notice you are causing scratches that are deep so just be cautious.
« Reply #2 on: July 03, 2025, 12:45:07 pm »
In general for factory single stage paint I have had good luck with Meguiar's Mirror Glaze #7.
for contamination, I generally use a clay or clay mitt, it technically also buffs/scuffs the paint.
My go to for Detailing and paint info is our own Resident Mike Phillips.  His forum has LOTs of good info on it.
https://themikephillipsforum.com/
https://www.youtube.com/@mikephillipsrealworlddetailing
https://www.youtube.com/@DrBeasleys
https://www.drbeasleys.com/
