Author Topic: Shift linkage pivot question  (Read 64734 times)
Offline Rough75C20
« on: October 05, 2025, 12:52:13 pm »
Hello was taking apart shift linkage on my 75 with a th350. Question is on the left side of the pivot where the spring and bushing are, is there anything that keeps this from coming out or the hole when the transmission isn’t in place? I took it off and have been looking around on the ground for an hour as I thought there would be something else to retain that rod in place. If it’s only the transmission that keeps it in the pivot please let me know. This pic I found on the internet shows nothing. I’m wondering if only the transmission and the connection to the shifter in the cab would hold it in place. It could have just been rusty when I pulled it out which gave it resistance but now that it’s clean it will slide right out without trans in place.
Thank you
« Last Edit: October 05, 2025, 12:55:44 pm by Rough75C20 »
Offline Rough75C20
Re: Shift linkage pivot question
« Reply #1 on: October 05, 2025, 01:04:01 pm »
Haynes manual also just shows the washer and bushing so I assume it’s just held in by transmission
« Reply #2 on: October 05, 2025, 11:27:12 pm »
There is no need for a retainer because ejection of the rod is blocked by the transmission.
Offline Rough75C20
« Reply #3 on: October 06, 2025, 06:39:02 am »
Thank you for the clarification bd.
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: October 07, 2025, 10:00:01 pm »
DANG! I thought we might actually have a active thread going... :(
Seems we're in a long dry spell.
I asked a couple of years ago (when the drought started) if inflation had slowed projects, got mixed responses.
Kinda seems connected to me.
20% peak was pretty steep.
1980 C-10 under construction
« Reply #5 on: October 08, 2025, 07:01:10 pm »
Http(s) is blocking this site from Google and many servers. There as also been an issue with the server crashing. I am sure this is deterring activity. I believe Chris is addressing this.
  • Old Goof
« Reply #6 on: October 14, 2025, 04:09:37 am »
I hope so, long for the good old (active) days.... :'(
