Author Topic: Help with shocks  (Read 39519 times)
Offline 01txdmax
  • Noob but not first rodeo
Help with shocks
« on: December 03, 2025, 10:54:41 pm »
Hi everyone, I'm struggling to identify the shocks I really need from 2000 miles from my truck.
1983 K30, 10k GVW, stock springs
All the configurators I find say this truck should take the same as the 1/2 tons by length, but that doesn't check out in my mind.
I just need a set of simple shocks to get the truck back on the road for a while before I do more. More might mean a bunch of things, so I'm thinking Monroe, KYB, etc but not $100 at a pop Bilsteins or others. I'm on the hunt because I pulled a 4" lift off of it and put the stock ride height springs in it, now those shocks are bottomed out.
Does anyone have any insight into part numbers or a reliable place to go find the right stuff?
Thanks
« Last Edit: December 03, 2025, 10:56:27 pm by 01txdmax »
1983 K30 454 SM465 with back to stock goals...
Re: Help with shocks
« Reply #1 on: December 04, 2025, 04:11:18 pm »
Front:
Monroe
34919
Also Fits   Gas-Magnum Suspension Shock Absorber Info
• Gas-Magnum Shock Absorber
KYB MonoMax
565069
• MonoMax • Maximum Monotube Performance Upgrade
KYB
KG5481
Also Fits   High Pressure Monotube Gas Shock Info
• Gas-a-just • Recommended O.E.M. Replacement
Rear:
FCS Struts
342529
KYB Gas-A-Just
KG 5482
KYB MonoMax
565068
344386
• Excel-G • Recommended O.E.M. Replacement
A.C. Delco
530-247
• Professional • Premium Gas Charged
A.C. Delco
525-21
Also Fits   Heavy Duty Rear Shock Absorber Info
• Gold • Heavy Duty
A.C. Delco
540-5018
• Specialty • Premium Monotube
Monroe
34920
A.C. Delco
520-116
• Silver • Mid-Grade Gas Charged
Monroe
RS55132
Also Fits   RS5000X Suspension Shock Absorber
Vendor Fitment   Vendor Comment
• RS5000X • with Rear Raised Height 0 (in) to 2.0 (in)
PRT PERFORMANCE RIDE
194267
 PRT Shock Absorber • Monotube Shock Absorber
174441
 PRT Shock Absorber
« Last Edit: December 07, 2025, 07:17:59 am by VileZambonie »
Offline 87ChevyR10
« Reply #2 on: December 07, 2025, 06:32:51 am »
These the yella fellas?
« Reply #3 on: December 07, 2025, 07:18:41 am »
Those are all part numbers for your application.
Offline 01txdmax
« Reply #4 on: December 08, 2025, 11:51:10 pm »
Thanks VileZambonie!!!
