Author Topic: Why doesn't fuel flow from the tank?  (Read 50048 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: March 09, 2026, 08:39:30 pm »
I have a titled 1974 Chevy c10 stepside.  I say titled because it has so many replacement junkyard parts on it.  I think the engine is from a 1976.  Anyway, it had an intermittent fuel starvation problem so rather than fool with it I just pointed the parts cannon at it and replaced all of the filters and the fuel pump.  In the process I prepared to plug the input to the fuel pump when I removed the hose.  But no fuel came out.  I put some air pressure on the top of the tank, and fuel comes out of the fuel line, but it doesn't free flow.  Appears not to be an issue, but can anybody tell me why that is?  Thinking maybe some kind of fuel line routing or special valve?  Oh the intermittent appears to be solved, but... it's an intermittent so it's going to take a few days to call it fixed....
Ricky
Offline zucchi
    • Driving my old car forever video channel
Re: Why doesn't fuel flow from the tank?
« Reply #1 on: March 10, 2026, 09:10:27 am »
There's usually a screen on the opening end of the pickup tube inside the tank. Remove the sending unit/pickup tube assembly and examine.
Why pay some inept wrench turner to break something, then claim it was that way when I brought it in, when I can break it myself for free and learn something along the way.
Offline fiddler
« Reply #2 on: March 12, 2026, 01:27:10 pm »
So you think the fuel should just flow out of the fuel line when I disconnect the fuel pump at the engine?
Ricky
« Reply #3 on: March 28, 2026, 01:45:16 pm »
Are you asking if it will siphon itself? You need the pressure differential for it to happen. If you are concerned about flow, perform a fuel volume test from the pump
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: May 26, 2026, 08:43:20 am »
might be bad rubber lines coming from the top of the tank to the hardline.  My trucks down right now for that very problem.  If those hoses are bad you'll be sucking air instead of fuel from the tanks.
