Author Topic: Motor Mounts  (Read 61282 times)
Offline roger97338
Motor Mounts
« on: March 10, 2026, 12:02:18 am »
I have a broken motor mount I need to replace, on the passenger side. The bolt that holds the two pieces of the motor mount assembly is absent. I'm just assuming the rubber part of the mount has been damaged by a broken bolt wobbling around in it for who knows how long.
Last time I replaced motor mounts, the engine was out of the vehicle. Easy peasy. Not so this time. Now I have all the things in my way.
So I'm looking for advice. Things I should do. Things I absolutely should NOT do.
Any input is appreciated.
75 Chevy 2wd; 350/TH400; lowered 3/4; headers; no a/c; not sure what else you might need to know.
Re: Motor Mounts
« Reply #1 on: March 19, 2026, 05:07:40 pm »
Support the engine, lefty loosey, righty tighty. lift the engine enough to remove and replace.
Offline JohnnyPopper
  • Old Goof
Re: Motor Mounts
« Reply #2 on: March 21, 2026, 07:39:29 pm »
For the work involved (not that much) I think I would replace the bolt to see if it's really broken.
I wouldn't even put the nut on at first.
If the motor pitches with the bolt in, then your assumption is correct.
If not, tighten the nut and bolt and go for a ride!
1980 C-10 under construction
Offline roger97338
Re: Motor Mounts
« Reply #3 on: April 08, 2026, 12:25:01 am »
I like that idea.
Re: Motor Mounts
« Reply #4 on: April 12, 2026, 04:37:37 pm »
The worst part is the fact that they used nuts and bolts instead of weld nuts. So you have to get an offset 9/16" wrench or make your own, to get in there and hold the nut. The mechanical fuel pump and lines running under the passenger side bracket don't help either. Have beer on hand.
Re: Motor Mounts
« Reply #5 on: April 18, 2026, 06:41:13 pm »
I just did a set of C10 motor mounts today and had to use my home made wrench. Tech Tip, wrap the flange nut in dum dum (butyl tape) and it will not fall out.
