Author Topic: Quality OE Fuel pumps?  (Read 9427 times)
Offline Scaryfastatx
« on: September 30, 2026, 10:21:05 pm »
Anybody have any guidance?
On my 305 dualjet with return, I had a carter pump and it lasted about 1-2 years
Finally gave out a few weeks ago
I ordered a Delphi and it was dead out of the box, wouldn't hold pressure unless I capped off the return line
Got a replacement Delphi shipped by the vendor
The replacement worked for about 30 minutes and then died, luckily I had some vice grips and was able to make it home.
The replacement won't hold pressure unless the return is capped also
It's crazy that you can't find a good fuel pump anymore
Offline Mr Diesel
  • Aaron
Re: Quality OE Fuel pumps?
« Reply #1 on: October 01, 2026, 08:24:19 pm »
Are you talking electric or mechanical pump?
1976 C20 Crewcab, 6.2L/SM465
1982 K30 Crewcab , 427TD/TH400
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
1986 K10 350/400. 1989 K30 cab/chassis 454/SM465
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: October 06, 2026, 08:36:36 pm »
sounds like mechanical.
1980 C-10 under construction
« Reply #3 on: October 09, 2026, 09:53:19 am »
Yeah, it's mechanical
So 3 Delphi, none of them had an orifice on the return bung, one of them worked for 30-45 minutes before it lost enough pumping capacity due to the full flow return
I didn't notice it didn't have the orifice was missing until I pulled it off
Also noticed the dreaded A stamped on the, so I guess Delphi white labels through Airtex
Pump #2
Pump #3
I ordered a Carter again, has the orifice and truck is back on the road, I'll take 3 years operation Vs 30 minutes any day
Offline Mr Diesel
  • Aaron
« Reply #4 on: October 09, 2026, 03:09:08 pm »
Garbage aftermarket. I could keep my old junk running forever if there was just some decent replacement repair parts.
I avoid anything stamped in China. Best option is usually Taiwan, followed probably by Mexico, U.S., and any other country besides China.
« Reply #5 on: October 14, 2026, 06:16:44 pm »
WELP!
the latest carter M6266 just died after 3 days
2 trips to work, and half a trip to the grocery store...
I've been testing the Delphi ones, and one of them with the return port plugged seems like it might work
Thinking about putting an in line orifice or maybe scavenging the orifice off of the M6266
Also thought maybe turning down some 0.060" jets and shoving them into the return hose
Offline Mr Diesel
  • Aaron
« Reply #6 on: October 14, 2026, 09:30:04 pm »
Can you open them up and find the points of failure? Multiple pumps doing this points to a likely problem elsewhere, unless you can pinpoint the reason for failure.
Last one that failed on me was a plastic pivot piece inside. China part. Replaced it with a Carter that was metal components instead. A carburetor requires very little pump pressure so your failure inside the pump should be pretty obvious.
« Reply #7 on: October 15, 2026, 09:10:47 am »
I agree with your take, but it has a new filter in the carb, a recently replaced the sock in the tank and at the same time I replaced the lines
when it first broke down I thought for sure it was the carb filter again, but no luck.
I havent opened them up, but put gauges on them and was manually pumping to check pressures
seems like most either have a weak diaphragm/inlet-outlet reed valves or are missing the return orifice
the Carter was only pumping 4psi with the return blocked off
One of the Delphi pumps was producing 7psi with the return blocked, but with the return open it was just pouring fuel back into my container.
I used fuel compatible clear tubing so I could see where the fuel was going.
« Reply #8 on: Today at 10:21:15 am »
Truck is back on the road, made it to work today no sweat and some extended cruising over the weekend
what I did was first try to remove the orifice from the return line on one of the pumps that I had, but it wouldnt budge
so I ended up getting an .060" orifice from a carb and machined/turned it down so it fit inside the return hose barb on one side, and the other fit snugly inside the hose
So far so good
its starting up much quicker, and doesnt need what I thought was a warm up with the older pumps.
I think these pumps are getting past QA/QC at the factory without any sort of flow testing or orifice
so with the 3/8 line feeding the pump, and a 1/4" full flow return, and a 3/8" line going up to the carb and through the filter and check valve, the return is seeing the majority of the fuel so the carbs bowl runs low
I think this can also cause some cavitation inside the pump which will run hotter and potentially cause some erosion/damage on the soft goods inside the pump, with the already lower quality materials we have now the pumps are dying quicker
so in theory with the orifice in-line it will only bleed off a tiny bit of flow since its the higher resistance line compared to the line going up to the carb
basically 3/8" in, 3/8" + .060" out should keep the bowl in the pump more full and reduce bubbles/vapor accumulation
Fingers crossed!
