Author Topic: Question about front axle shaft and leaks  (Read 12399 times)
Offline Kevin108
« on: June 20, 2002, 09:21:00 pm »
I replaced the seals today and the passenger side is still leaking, I guess because the axle shaft is worn where it meets the seal.  Any other possible reason?
Randy's R&P wants $45.50 for just the shaft.  The outer stub's good but I'm gonna need the u-joint too.  Does that sound like a deal, should I call around locally, or is there somewhere online with better prices?
87 Silverado 4x4 Longbed Pickup
My Mods | Truck Pics | E-mail Me
Re: Question about front axle shaft and leaks
« Reply #1 on: June 20, 2002, 11:11:00 pm »
Are you sure it isn't just residue seeping from the axle tube? was there a groove in the axle?
Offline Kevin108
« Reply #2 on: June 21, 2002, 08:12:00 am »
Oh my God, you might be exactly right!  I was so tired after I finished that as soon as I saw it running down the inside of the tire again I didn't even think twice.  I'll check it out and post the results, I think there's a good chance you're guessing correct.
« Reply #3 on: June 27, 2002, 09:33:00 pm »
So was it left over spooge?
Offline Kevin108
« Reply #4 on: June 27, 2002, 11:27:00 pm »
Unfortunately no.  Randy's R&P wants like $55 for just the shaft.  Local they want $125.
Edited by: Kevin108 at: 6/28/02 4:28:44 am
« Reply #5 on: June 29, 2002, 10:11:00 pm »
hmmm, I'd check to make sure the seal is installed properly, if there is no groove in the shaft and the seal slides on there nice and clean, maybe it's just not in right. Did you lube the lip of the seal with some new grease or oil b4 you installed it? Did you apply any sealer around the exterior surface?
Offline LOSTONE65
« Reply #6 on: July 02, 2002, 12:10:00 am »
dang kevin you go from on POS to another!!!
JEEPBOUND OFF-ROAD!!
Capital Off Road Enthusiasts, Inc.
I LIKE CHEVYS........they taste like chicken
Offline Kevin108
« Reply #7 on: July 06, 2002, 09:30:00 am »
Dell - It's in there right.  The seal fits really tightly, it's pretty impossible to install it wrong.  A bad seal is possible I guess...  Did lube the contact area, didn't add any sealer.
Chad - I know man, it sucks!  I guess I just can't have nice things.  Heh heh.
