4 Wheel Drives
Who Makes Best Lift Kit???
Topic: Who Makes Best Lift Kit??? (Read 4583 times)
js9234
May 04, 2005, 10:37:00 am »
I need a Lift Kit big enough to fit 36 x 14.5 so I figured a 8 in would work. Who makes the best for these model trucks. Mine is an 81 1/2 ton. I had a post before about BDS Suspension but didn't have many replies. I need one that also comes with everything.
Re: Who Makes Best Lift Kit???
May 04, 2005, 10:47:00 pm »
A 6" suspension lift would be fine. skyJacker, rancho and many others are reputible. Get a steering arm, Adjustable Drag link, and a good dual steering stabilizer too.
roundedline
May 05, 2005, 09:56:00 am »
I agree, any of the top names in suspension are good.
www.tuffcountry.com/
has a reputation for being a good soft spring rate that provided good articulation and ride.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
http://www.73-87chevytrucks.com
http://www.captkaoscustoms.com
bflobil
June 26, 2005, 10:12:00 pm »
I put a 6" Skyjacker lift on my 86 k-10 and am VERY pleased with it. I had to get the drop swing arm to get most of my turn radius back and also had to get the brake line extensions. I have 35" tires on it now and occasionally hear a little tire rub. I didn't get the rear springs because I don't have too much horsepower to worry about axle wrap and in the past I had allready had the springs rearched and added a leaf. The ride is a little more "sharp" than stock but it really "soaks" the bumps up well. I hope this info helps you.
Drive fast and take lots of chances!
4 Wheel Drives
