4 Wheel Drives
what size tires can i put on...
Topic: what size tires can i put on... (Read 6722 times)
784x4ron
New Users
October 06, 2005, 09:50:00 pm »
i have a 1978 chevy k10 3/4 ton 4x4 i,m putting a 3" body lift on it.can any one tell me what are the biggest 15"tires i can put on it with out cutting the finders down. i would like too put 35x12.5x15..it,s still stock and i have 33x11.5x15" on it now. thank you...
roundedline
Re: what size tires can i put on...
October 07, 2005, 10:53:00 am »
You need 4" of lift to clear 35x12.5's without rubbing. Technically you shouldn't be able to clear 33's on a stock truck. Have the fenders been clearanced?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
http://www.73-87chevytrucks.com
http://www.captkaoscustoms.com
79GMC4x4
November 02, 2005, 12:13:00 pm »
I currently have a 79 3/4 Ton 4x4. It is stock and it also clears 33's.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
November 02, 2005, 05:44:00 pm »
Ensure your rear axle ratio can handle that size tire. If it is a high gear rear, you may want to lower your ratio. Large tires make a big difference in rear end ratios.
SgtDel
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
1976Scottsdale
November 02, 2005, 09:10:00 pm »
Yes, that is true. I have 3.08 posi's in my 78k10 and that poor thing will barely go up a hill and hold speed with the 33's on it. 3.42 will do fine, 3.73's are better, but 4.10's are... dare I say it, God-like. Hope gas milage is of no consequence.
Lt.Del
Andy aka:SgtDel
November 03, 2005, 11:22:00 am »
I have a 91 sub w/ 33's on her. The rear is a 3:73, which, with those larger tires, translates to close to a normal set up 3:08 rear, when you look at the rpm's.
SgtDel
www.HikerMania.com
DieselTech
November 14, 2005, 06:34:00 pm »
My 78 has 38.5"s on it with 4.88 gears. A little too low sometimes, but with 3.73's it was a total dog. It now gets up to speed like it should, but runs around 3200 Rpm's at about 65 mph. Gas mileage is terrible! Big trucks drink the gas!
4 Wheel Drives
