Author Topic: Stupid th-350  (Read 11017 times)
Offline 79ChevyK20Guy
  • The clothes don't make the man!
Stupid th-350
« on: December 03, 2006, 11:37:00 pm »
I just finished replacing the transmission in my 1979 Chevy K20 for the tenth time. WTH is wrong with th-350's? they just won't hold up to my 400 sbc no matter what you do to them they average between 13k to 25k miles and then first gear will go out. I am running an 400sbc bored .40 over with a .760 solid lift cam, an Edlebrock torker intake with a Holly 750cfm double puper carb, long tube hooker headers with 40 series delta flow flowmasters. The engine is only pushing 450+ Horse power. I am running 4.11 gears with a posi rear and limited slip front, a New Process 203 transfer case. I just don't know what to do, I don't want to swap in a 700r4 because I want to keep the same transfer. Any suggestions?
Brian Skaggs
"Sometimes you just gotta say WTH?"
Offline roundedline
Re: Stupid th-350
« Reply #1 on: December 04, 2006, 11:58:00 am »
Who is rebuilding them for you?  If they have done all 10, I would find someone else to build them.
How are you driving the truck to break ten?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Re: Stupid th-350
« Reply #2 on: December 04, 2006, 02:38:00 pm »
The one I just put in I built myself. The truck gets used daily on the farm I work at. Although this past time he truck never even got hooked to anything and the transfer case broke off the back of the transmission case. The transmission before that only had 1200 miles on a rebuild (Rodger's Automatic Transmissions) I have always had good luck with them previouse times but that time I never pulled anything with it or took it off road and I only drive 7 miles to work and first gear went out in it. Everytime it is always first gear after about 25k miles.
Brian Skaggs
Offline 1976Scottsdale
TH-350
« Reply #3 on: December 04, 2006, 06:50:00 pm »
Have you done any of the upgrades?  Red Line clutches, Shift kit, NEW ~1600-2200 stall converter, Hardened Intermediate Sprag, extra clutches, etc?
Re: TH-350
« Reply #4 on: December 04, 2006, 08:10:00 pm »
The first thing to do would be a failure analysis. What failed and why. You can't look at the transmission as a whole. If you do not have the means or knowledge to determine what keeps causing the failure take it to someone who can. The TH350 is a good trans and can be easily midified to take severe punishment with relatively low cost.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: TH-350
« Reply #5 on: December 04, 2006, 09:17:00 pm »
This may seem obvious, but, are your sure you  check your transmission fluid correctly?  I mean, many don't check it while the tranny is warm.  they check it cold.  This makes a huge difference in fluid levels.  If you check it cold, it may read o.k. but in reality be two quarts low.  Running it too low on fluid will burn it up in a heartbeat.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 12/4/06 9:18 pm
Re: Stupid th-350
« Reply #6 on: December 06, 2006, 07:48:00 pm »
Yes i have been checking fluid correctly, it has a 3100 rpm stall converter. It has all the modifacations done to it. This past time, one of the gears sheared in two. I just don't know what I am doing wrong.
Brian Skaggs
Offline Pushrod
Re: Stupid th-350
« Reply #7 on: December 06, 2006, 10:53:00 pm »
Gear Ratio?
Tire Size?
Do you use the radiator/trans cooler or a seperate trans cooler from the radiator or a combination of the two inline?
Trans cooling lines kinked, smashed, or twisted?
Junkie 77 Stepside AKA "The Sanford Machine"
81 Malibu 350 and a 4 speed
Re: Stupid th-350
« Reply #8 on: December 07, 2006, 02:53:00 pm »
The cooling lines are new, it has a 4.11 gear ratio with 33x12.50x16.5 tires. It has a seperate cooler because the last time I thought that could be the problem so I bought a trans cooler.
Brian Skaggs
Re: Stupid th-350
« Reply #9 on: December 07, 2006, 05:43:00 pm »
It's good to run an auxiliary cooler but you should maintain the OEM cooler also. It acts as a temperature stabilizer/regualtor.
What gear shredded in two? There is a planetary gear set in your transmission but there isn't a one specific gear. Gear ratio's are acheived through the interaction of holding one member and driving one member of the planetary gear set. If your planetary gear set failed tell us exactly what part of it broke so you can fix the problem not just the symptom this time.
Re: Stupid th-350
« Reply #10 on: December 08, 2006, 06:03:00 pm »
It was the one that goes in in front of the output shut that looks kinda like a drum, can't remember what it is called
Brian Skaggs
Offline roundedline
Re: Stupid th-350
« Reply #11 on: December 09, 2006, 11:06:00 pm »
Ok, guessing by your description if sounds like you are talking about the pump.
Where on this pic are you specifically talking about?
Project Su
Jimmy 2WD Project
Re: Stupid th-350
« Reply #12 on: December 10, 2006, 05:04:00 pm »
Row D number 97 the end sheared off of it.
Brian Skaggs
Re: Stupid th-350
« Reply #13 on: December 11, 2006, 07:56:00 am »
That's your low reverse output ring gear. If this is the same component that is failing I would check to see if there is unecessary stress on the output shaft. Are your driveshaft angles correct? Is the rear pinion angle correct? If the truck is lifted did you lower the transfercase? Is the driveshaft slip yoke adequate? If everything checks ok I would suggest upgrading to the TH400 and doing a thorough overhaul. Have a different trans shop do it this time though :lol
Re: Stupid th-350
« Reply #14 on: December 11, 2006, 07:12:00 pm »
Everything sits at stock hieght, the problem with installing a th-400 is that I would have to change the transfer case input or the case itself and I don't wanna do that because it's a pita. I appreciate everyone's advice and if this transmission doesn't hold it the truck will be for sale!
Brian Skaggs
