4 Wheel Drives
Poping noise?
Topic: Poping noise? (Read 5322 times)
79 4x4
Poping noise?
May 04, 2006, 03:59:00 pm »
When I turn there is a poping noise coming from the front end. It is only when I am moving. If I am siting still it does not do it. What should I check? Nothing obvious looks like it is moving.
roundedline
Re: Poping noise?
May 04, 2006, 04:50:00 pm »
I would check the front frame area near the steering box first. Are you running large tires?
Does it do it more turning or straight, or ....
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
http://www.73-87chevytrucks.com
http://www.captkaoscustoms.com
Z28 c10
Re: Poping noise?
May 04, 2006, 05:53:00 pm »
what type of hubs are you running? Is it possible that you have a busted spider gear in the diff?? Also are you certain that its popping in the front? If its in the rear, you most likely have a spider gear broke or a busted tooth on your ring or pinion.
JayTater
Z28 C10
Blazin
Blazin new trails!
Re: Poping noise?
May 04, 2006, 10:43:00 pm »
How bout the axle joints?
79 4x4
poping noise
May 04, 2006, 10:58:00 pm »
Im pretty sure it is the front end, I stuck my head out the window a couple of times while turning. I checked the frame and didnt see any cracks or anything. that was the first thing I thought of that and u bolts but it all looks ok. I just replaced the hubs due to bad bearings that spun the races, and have warn 1/4 turns. The diff is full of oil and 4 wheel is disengaged.
Redneckchevy
poping
May 09, 2006, 08:19:00 pm »
Try jacking the side up thats poping put gloved on grab ur tire and shake up and down left and right and all around...Alot of times a loud poping can be cut of a tie rod end or ball joint ...or sometimes a unaversal..
PineCreek
Re: poping
May 11, 2006, 07:04:00 pm »
What does it mean when there is play when you shake it up and down? Mines been making a noise and I just checked it like suggested.
Re: poping
May 11, 2006, 08:06:00 pm »
Check the ball joints for axial play and if they look tight but the wheel moves it's your wheel bearings.
4 Wheel Drives
Poping noise?
