Author Topic: sm465 tranny help  (Read 8698 times)
Offline usmcchevy
sm465 tranny help
« on: March 14, 2006, 11:14:00 pm »
i rebuilt my sm465 tranny. now i cant get the top cover back on. can anybody tell me how to put the top cover back on. i tryed for a while put i cant figure it out. thanks
Re: sm465 tranny help
« Reply #1 on: March 15, 2006, 04:19:00 pm »
Move all transmission gears to neutral except the reverse idler gear which should be engaged approximately 3/8 of an inch (leading edge of reverse idler gear taper lines up with front edge of 1st speed gear). Install cover assembly. Shifting forks must slide into their proper positions on clutch sleeves and reverse idler gear. Forks must be positioned as in removal.
Install cover bolts and tighten to 20-25 ft. lbs .
Offline usmcchevy
« Reply #2 on: March 16, 2006, 06:17:00 am »
i tryed that, my haynes manual says the same thing.should it just sit right down on there or do you have to play with it for a while. it was pretty hard to gett off also.
