Author Topic: wheel studs  (Read 8769 times)
Offline dragmine
wheel studs
« on: April 02, 2006, 10:09:00 am »
Hey folks. Im having a problem locating longer wheel studs for my 78. I bought new wheels and they call for 1 and 1/2 the diameter of the stud which is 3/4" I have 5/8"thread not enough.Im trying to locate hardened studs for the rear 10 bolt as i drag it.And longer ones for the rotors.ARP and Moroso do not list any thing.Any ideas on cross reference from other vehicles or companys that might make some. I can supply specs. if needed .    thanks.
Edited by: dragmine at: 4/3/06 8:00 pm
studs
« Reply #1 on: April 02, 2006, 09:45:00 am »
Just go to an autoparts store and match them up...
or look online. Google wheel studs
www.moserengineering.com/...p?CatID=17
Offline DnStClr
Re: studs
« Reply #2 on: April 03, 2006, 08:34:00 pm »
You have 3/4" diameter wheel studs?! Whew.
Don
87 Chevy Silverado
Offline dragmine
Re: studs
« Reply #3 on: April 04, 2006, 05:37:00 am »
good eye.No! 1/2" stud.And ive been to the local parts store.All I need is 1/4 to 1/2" longer stud.A  Ford econoline will fit the rotors which  is longer but the nurl is not quite the same,but I think they will work.Its the rear I am having problems with.I dont really want to drill the axles
Offline flyboy9994
Re: studs
« Reply #4 on: April 05, 2006, 07:03:00 am »
Try a Summit Racing or a Jegs catalog. Summit has Moroso wheel studs 1/2" X 3" long in 4 different knurl sizes.
Hope this helps.
Randy in Kentucky
Randy in Kentucky
1977 Cheyenne LWB
Offline dragmine
Re: studs
« Reply #5 on: April 05, 2006, 08:58:00 pm »
Thanks.I did not know they had the different nurl sizes.The list I got on line only had one close.Ill give them a call.Thank again. Jim Nova Scotia.
Edited by: dragmine at: 4/5/06 7:59 pm
