Author Topic: Stuck Wheel  (Read 9963 times)
Offline 123 pugsy
Stuck Wheel
« on: April 02, 2006, 10:43:00 am »
How do you get a wheel off when after you take off the lug nuts and it won't budge?
Pugsy
76 C10 LWB
TPI 350
Re: Stuck Wheel
« Reply #1 on: April 02, 2006, 09:47:00 am »
soak it with some penetrating oil. Place one lug nut back on loosely, spin it and smack the back side with a 3lb sledge.
Offline 123 pugsy
Re: Stuck Wheel
« Reply #2 on: April 03, 2006, 06:08:00 pm »
A couple of squirts of WD40 at each lug and a couple of shots with my hands and off it came .Thanks for the tip.
Pugsy
76 C10 LWB
TPI 350
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
> Re: Stuck Wheel
« Reply #3 on: April 03, 2006, 07:20:00 pm »
You jack it up first.
SgtDel   <------Bowing.
Offline 1976Scottsdale
wheel
« Reply #4 on: April 03, 2006, 11:42:00 pm »
Well, there are to ways that I use: 1-the back kick... kick the rim with the back of your shoe while jacked up. 2-put a fence post on the back of the rim from the other side of the truck and hit it with a B.F.H.
Offline Redneckchevy
    • Photo Bucket
Re: wheel
« Reply #5 on: April 09, 2006, 02:52:00 am »
yea i gotta say kick it...and if that dont work get mad at it ...a 100 pound tool box getting hurld at it works also..But anyways Kicking does work i mean u never want to sit in front of it and try to pull on it...be safe and smart.
Offline 123 pugsy
Re: wheel
« Reply #6 on: April 09, 2006, 07:22:00 am »
I read somewhere that a guy put the 5 lugnuts on loosely and drove in circles.
Pugsy
76 C10 LWB
TPI 350
Offline maxwell75c10
wheel
« Reply #7 on: April 10, 2006, 10:31:00 pm »
my auto shop teacher had the same problem on a 75 c10 like mine. not even driving with no lugs worked. so he had to torch it. it happens because of the tigth clearence between the rim and the spindal. so i suggest when you can, put anti-seize alover the contact points.
