73-87 Chevy & GMC Trucks
Power Brakes
Topic: Power Brakes (Read 7012 times)
123 pugsy
Power Brakes
April 22, 2006, 11:11:00 am »
Took the truck for a drive.Booster gives a whoosh sound and power assist doesn't seem to be working.Is it possible to install this wrong?The brakes were working before I ripped the truck apart.
Pugsy
76 C10 LWB
TPI 350
Re: Power Brakes
April 22, 2006, 11:18:00 am »
After you shut off the truck does it maintain vacuum after you pull of the check valve?
123 pugsy
Re: Power Brakes
April 22, 2006, 01:07:00 pm »
Yes.Sorta.Just checked with mityvac.Leaking slightly around the grommet only.Step on the brake pedal and vac is released immediately.
Edited by:
123 pugsy
at: 4/22/06 12:34 pm
Pugsy
76 C10 LWB
TPI 350
Re: Power Brakes
April 22, 2006, 06:43:00 pm »
Then you have a bad booster
WickedC20
Re: Power Brakes
April 26, 2006, 05:37:00 am »
Order the booster and Master as a unit, I paid 175.00 for both a few years ago.
Dont over adjust or under adjust the booster rod, makes stopping such a pain
Power Brakes
